It is currently Wed May 22, 2013 2:05 pm
Post new topic Reply to topic  [ 77 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Sat Jan 22, 2011 10:03 pm
Hi Ruben,
Nothing wrong with aspirations. But bear in mind that the 550D/T2i sensor should just as good as the 7D for astrophotography. And I'd also avoid using high ISO numbers. My personal choice is 400 but 800 is also commonly used. It's a trade-off between thermal noise and sensor readout noise, as I understand it, but I've not gone into this in any depth. You might find Christian Buil's 40D tests an interesting read.
PostPosted: Sat Jan 22, 2011 10:20 pm
Thanks Bob, seems to be an interesting read for a boring sunday! I know the 550D has the same sensor, but I really want the better build and higher framerate;)
PostPosted: Sun Jan 23, 2011 7:35 am
Hi Bob, seriously tempting scope, so long as high power work is your thing... lots of lovely high resolution planetary and lunar shots coming up!
(Actually I've seen plenty of great deep sky stuff too with SC scopes)
PS - ruben, yep, I'd go down the webcam route first of all for experimenting with high power imaging / stacking.
PostPosted: Mon Jan 24, 2011 8:17 pm
Webcams are what a lot of astrophotographer start with then looking at planetary / lunar imaging. I think the Philips Toucam was the best bet, although you would be hard pushed to find one now.
That scope looks like a serious piece of kit there too!!!! Im just about to invest in an Atik Titan for my setup so I can guide my imaging on DSO's.
Lee Diggle
PostPosted: Tue Jan 25, 2011 11:34 am
Hi Lee,
I was about to agree with you about the webcam but I've just noticed that SBIG have previewed a dedicated Planet Cam and Autoguider:
The product page has more details, including some nice animations, but here are the headlines:
      ST-i PLANET CAM AND AUTOGUIDER
  • Low noise, high sensitivity CCD - Monochrome or Color
  • Internal mechanical shutter for automatic dark frames
  • Electronic shutter for short exposures
  • Up to 21 frames per second in focus mode
  • 16 bit A/D
  • Eyepiece size body (1.25" diameter)
  • Low cost
  • Lightweight - only 2.2 oz.
  • Powered from USB Port
  • Standard Guider Output Port
  • Front end threaded for standard 1.25" filters
  • CCDOPS Autoguiding and Imaging Software with Planet Master™
  • CCDSoftV5 Autoguiding and Imaging Software Software
    The ST-i Planet Cam and Autoguider adds features unavailable elsewhere in a camera of this size and price. A high performance compact camera that is an excellent guider and very capable Planet Camera. The body is light weight, no larger than many 1.25" eyepieces. In fact, it is 1.25" in diameter, 3.5" long and weighs only 2.2 ounces. The camera receives both control signals and power from the USB port of your computer, so only one thin USB cable is required for using the camera as an imager. For guiding, a standard, opto-isolated, autoguider output port is located in the back panel.
Not available until April/May and the suggested retail price of $595 may seem a little high but I've a feeling that this little shotgun cartridge might be very good value... 8)
PostPosted: Tue Jan 25, 2011 11:39 am
Now that looks like a nice piece of kit. Got a faster frame rate than the Titan and looks pretty slick too. I like the shotgun cartridge feel.
It will be interesting to see what reviews emerge on this one!
Lee Diggle
PostPosted: Tue Jan 25, 2011 11:59 am
Hi Lee,
Agreed. I'm doing some serious window shopping right now with a view to possibly pulling the trigger next year on that Celestron I mentioned above and it looks like that ST-i could do dual duty very handily as an autoguider behind my little TeleVue Pronto and as a planet cam behind the Celestron and SBIG are even promising OS X compatibility. 8)
At the other end of the scale I've been drooling over the possibilities of a Starlight Xpress SXVR-H18 fitted behind a HyperStar lens. Unfortunately I think the Atik cameras may be bulkier than I would like for that application but the Titan might well be an alternative to the ST-i.
But while I can find press releases for the Atik Titan I can't find the product page. Have you got a link you can share?
PostPosted: Fri Jan 28, 2011 1:47 pm
Hi Bob,
I also cannot find a product page for the Titan (mine was delivered yesterday :)) which is odd. Why sell a product and not put it on their website? I do know of another forum which has a brief review of the Titan which I can post if it doesn't break forum rules?
One thing I have found though is I still need to run windows to autoguide with the Titan as PHD on the Mac doesn't work :(, still Im probably missing something knowing me, lol
Of course, I can do my own mini review here once Ive worked it all out etc ;)
I dream of getting a large format CCD in the future but that will take some saving I think. I must admit I do like the Starlight Xpress and SBIGs.
Lee Diggle
PostPosted: Fri Jan 28, 2011 4:42 pm
Just found this when researching Backfocus
http://www.atik-usa.com/atiktitan.html
Lee Diggle
PostPosted: Fri Jan 28, 2011 6:25 pm
Great job. I'm still struggling through a fog of specifications for all sorts of kit at the moment. Hopefully the mist will be thinning by the summer. 8)
But I have got myself on SBIG's list of contactees for when that Planet Cam and Autoguider is released.
PostPosted: Fri Jan 28, 2011 8:00 pm
I know the feeling Bob. It took me ages to wade through the fog before I finally made my mind up!
Lee Diggle
PostPosted: Sat Mar 19, 2011 1:45 pm
In this post above I drew attention to SBIG's preview of their dedicated Planet Cam and Autoguider. While browsing the Starlight Xpress site I see they've had a similar idea with their newly announced CoStar, which also fits into a 1.25" eyepiece holder:
      CoStar Specification:
  • Imager type: Aptina MT9M001 mono cmos chip with low dark current and anti-blooming.
  • Full resolution Pixel data: Pixel size: 5.2uM x 5.2uM, Image format: 1304 x 1024 pixels
  • Image area: 6.66mm (Horizontal) x 5.32mm (Vertical).
  • Spectral Response: QE max at 620nM (~65%), 35% at 400nM and 770nM.
  • Readout Noise: Less than 40 electrons RMS - typically only 20 electrons.
  • Anti-blooming: Overload margin greater than 1000x.
  • Dark current: Dark frame saturation time greater than 10 minutes. Less than 1 electrons/second @ + 10C ambient.
  • Data format: 10 bits.
  • Computer Interface: Built-in USB 2.0 compatible interface.
  • Image download time: Typically 0.1 seconds at full resolution using USB 2.0.
  • Power requirements: USB powered.
  • Cooling system: Ambient air cooling.
  • Size: 32 x 60mm black anodised aluminium barrel with 25 x 0.75mm 'C mount' thread at the CCD window end & input/output plugs at rear.
  • Weight: approx. 45g.
Comparing this with the SBIG equivalent shows some fairly significant differences and, arguably, the SBIG wins many of the comparisons but the CoStar is significantly cheaper and also has a larger pixel count and smaller pixel size which may be useful for some.
Update: The sensor manufacturer's name, Aptina, rang a few bells and I remembered their DR-Pix Technology announcement which I flagged here. The MT9M001 sensor (product page) used in the CoStar doesn't appear to use that technology but one thing that the data sheet flags that is missing from the CoStar specs above is a 30 fps progressive scan 1280x1024 video mode. :shock: 8)
Maybe the Starlight Xpress driver can't deliver this or maybe Starlight Xpress forgot to mention it but if that mode is available then the CoStar becomes even more interesting. If I find out more I'll post in this thread. 8)
P.S. For a higher spec device in terms of sensitivity and read noise, albeit with a lower pixel count and larger pixels, that also uses the same 1.25" form factor Starlight Xpress offer their Lodestar.
PostPosted: Sat Mar 19, 2011 3:21 pm
In response to my enquiry regarding the possibility of fully utilising the 30 fps of the Aptina MT9M001 sensor in the CoStar camera referred to just above I've just had the following reply from Terry Platt at Starlight Xpress:
    We are slightly restricted by the USB chip, which drives the sensor, and it runs at 15 FPS max. at the moment. It's possible that improved firmware could increase this at some time in the future.
So, not quite such good news as one might have hoped for but the CoStar still looks like good value to me. And full marks to Starlight Xpress for responding so quickly to the question. 8)
PostPosted: Sat Mar 19, 2011 8:54 pm
When it comes to planetary/lunar/solar imaging, I would go the router of Imaging Source DMK CCD camera as the best for the $$. I got mine this week
This is the spec from the manufacturer :
http://www.theimagingsource.com/en_US/p ... dmk31au03/
I came back for an 1 hour session where I tried the camera on a microscope c-mount and through an Orion 80ED during daytime. The image I was getting was very sharp. I am hoping that I could do Saturn tonight and maybe a few capture of the "SuperMoon".
PostPosted: Sat Mar 19, 2011 10:05 pm
Congratulations on the new camera. 8)
Hope you can share a few astro photos with it on the forum in due time.
