It is currently Thu May 23, 2013 9:04 am
 Post subject: bird photography
PostPosted: Mon Dec 27, 2010 5:26 pm
hi all i need some help and tips, basical;ly i will be spending a day at a falconry center taking pictures of the birds they have and need some tips and advice to get the best shots from the equipment I have.
I have
sony a390
tamron 70-300(cheaper version)
sony 18-70
tripod
i plan on taking some static shots and flying shots so any help or advice on how i can get the best from my current equipment would be great as i am a novice at this but would like to capture some shots of owls and hawks in flight.
many thanks
james
PostPosted: Mon Dec 27, 2010 5:36 pm
If the center is small or enclosed, you probably don't need a lot of zoom - either lens would be about equal - if larger, the zoom will probably help you more - though how much daylight you have will affect your performance as neither lens is particularly fast. The zoom could be good for closeups too.
In general, the tripod probably won't do much good - birds don't sit too still, so long exposures are out, and you don't have any really heavy lenses that couldn't be handheld - I'd think you're best just handholding and maintaining maximum movement and flexibility.
I'd probably recommend sticking with either P mode or A mode, since you're not too familiar with this type of photography - the one thing I'd recommend is watching your shutter speed and making sure if shooting any moving birds that it be at 1/500 or faster. If shooting a sitting bird, you could likely get away with 1/100 or so without too much problem. Use spot focus mode - it'll probably be best so you can ensure you focus on the bird - in general, try to always focus on the bird's eye, as that's the best spot to make sure you have in focus. I'd set your focus to AF-S mode - single focus - continuous isn't as useful unless you really know how to shoot moving or flying birds - with single AF, you can half-press the shutter to lock focus where you need, then fully press to trigger the shutter. I'd also put your drive mode in 'continuous'...your camera isn't super-fast on frame rate, so in continuous mode, a quick press of the shutter will still get you one shot...but holding down the shutter will let you take a few - as many as you want or need by just holding the shutter down. I'd recommend shooting often - take multiple shots of each bird in each pose - if you have slower shutter speeds, there will inevitably be moments a bird flinches, moves, blinks, darts its head - and you'll get some blurry shots. Take 3 or 4 shots of each pose, and one of them is more likely to come out right - take only one, and if the bird moved in that moment, that's one shot in the garbage that can't be corrected.
Hope that helps.
Justin Miller
Galleries:
PostPosted: Mon Dec 27, 2010 6:26 pm
For static photos, I'd suggest A mode. The depth of field can be less than you think, depending on how close you get. Following example was taken at f/11 and just about gets the eyes and beak into focus.
If you're much further out then you can get away with bigger apertures. Do review at the time, and/or take shots at wider and stopped down to hedge the output.
Like Justin said, they do tend to move around, and the longer exposures will open up a motion blur risk, plus I'm sure some of their eyelids are synchronised to my shutter. Taking several shots will help you get a great one.
Oh, if the bird is quite contrasty like the harris hawk above, lower ISO will give you more dynamic range to keep the detail in both dark and light areas. When I first took the above shot I had auto ISO on, and I found I was borderline clipping the highlight detail (beak). Reducing to ISO400 solved that for me at the time.
For flying birds with unpredictable paths, I'd suggest S mode set to 1/500s or even faster if light allows. I would use continuous AF and continuous shooting, centre point AF. Keep the bird centred and crop to frame if needed when you get home. Expect a significant number of duff shots. If they fly repeatedly on a predicable flight path, you can try manual pre-focus instead and wait for them to go into the target zone.
PostPosted: Mon Dec 27, 2010 6:43 pm
thanks alot both of you for the tips and advice. this is something that is interesting me more and more(bird photography) and i think i will persue it further.
thanks again guys
james
PostPosted: Mon Dec 27, 2010 7:31 pm
No problem - if you do get addicted to it, I'm afraid I have bad news for you - it's going to start hurting your wallet. You're going to want a longer zoom lens, then a faster continuous frame rate body, then a faster longer zoom lens, then a higher-res body, then a long prime lens, then a new camera body with even faster continuous frame rate and more focus points, then a faster long prime lens...
It keeps going on and on. Fair warning!
Justin Miller
Galleries:
PostPosted: Mon Dec 27, 2010 8:17 pm
haha i think its already started im already looking at my next body and lenses.
PostPosted: Mon Dec 27, 2010 9:00 pm
Here's an interesting, humorous and informative film on Bird Photography. It is broken up into the three parts:
Part 1:
Part 2:
Part 3:
Type in bird photography in to youtube and find a lot of good footage and people talking about it.
PostPosted: Mon Dec 27, 2010 10:25 pm
Interesting set of videos there Capital, pretty dedicated guy.
Some members from a bird forum that I belong to travel the world to add to their “life-list”.
