It is currently Fri May 24, 2013 2:20 am
Post new topic Reply to topic  [ 25 posts ]  Go to page 1, 2  Next
 Post subject: Submitting a picture
PostPosted: Fri Jan 25, 2008 6:57 pm
Gordon I am not able to post a picture on On assignment and how do I creat a link? say to Fotik.com[url]rsunsets@msn.com[/url]
PostPosted: Fri Jan 25, 2008 8:07 pm
Hi rsunsets,
Forgive me for butting in!! :D
Have a look at this topic, in which forum moderator Thomas explains how to post a picture.
 Post subject: Posting Pictures
PostPosted: Fri Jan 25, 2008 8:24 pm
Many thanks for trying to help but if it takes all that, I will not be able to submit my work as I don,t understand the answer Thomas gave,what part of all that typing is supposed to be put in ? For me this Rocket science and very confuseing.
EDIT: Added by Bob Andersson to allow you to see how adding an image can be done. Click your Edit button to see the text.
1/ Simple Image
2/ Image with hyperlink
Note that the image must be stored somewhere on the Net (Flickr, ImageShack etc) - it can't be stored on the CameraLabs server! Hope this helps.
PostPosted: Fri Jan 25, 2008 8:44 pm
Hi rsunsets,
I've taken the liberty of adding a few lines to your previous post. Click the Edit button in that post to see how it is done. The [img]..[/img] and [url=..][img]..[/img][/url] bits are all described in the BBCode help page which has a link to the left of the edit box when you are writing a post (or click here).
 Post subject: Thanks
PostPosted: Fri Jan 25, 2008 9:56 pm
I know this is not all that hard and that you all mean well but syntex typing or what ever this is, is something I will most likely have to get a beginners book about because I not getting any of this call me thick headed anybody know of a book or web site? Wikipeda? I,ll try there!
Anyway Many thanks
PostPosted: Fri Jan 25, 2008 10:37 pm
Ok, let's go step by step.
First of all, you should upload your photo to a hosting service of your choice. I use Flickr, and one of my pictures can be seen on the following page:
http://www.flickr.com/photos/luis_pt/1603704203
That's called a URL (the "http://www...").
Note that the URL is not of the photo itself (it doesn't end with ".jpg"), so we'll need to use this instead:
http://farm3.static.flickr.com/2021/160 ... 1591f4.jpg
Now, how do I make that photo appear here?
I wrap some tags around the URL, like this:
Code:
[img]http://farm3.static.flickr.com/2021/1603704203_aa291591f4.jpg[/img]
Notice the "[img]...[/img]" tags. That's what will make the photo appear.
So now we can see it like this:
Try this with one of your photos, and then we'll try to add a link to it (so that others can click on it and see the original).
I hope this helps. :)
Nikon D90 + MB-D80 + SB-600 + AF-S VR 18-200mm f/3.5-5.6 + AF-S 35mm f/1.8 + AF 85mm f/1.8 | My photos on Flickr.
 Post subject: Luis
PostPosted: Fri Jan 25, 2008 10:44 pm
1st thanks for not giving up and I understand that part about wrapping the tags but where? in my response on my post on CL or at flicks or ...? and arent they called brackets? img=image?
Edited by Thomas:
Just like this! If you edit this post you will see.
Pure image without link:
Pure link without image:
http://www.flickr.com/photos/38912116@N00/2197356359/
And now onto the next level: A pic with an embedded link:
PostPosted: Fri Jan 25, 2008 10:56 pm
Please copy and paste the URL of the page that is hosting your photo and we'll continue from there.
PostPosted: Fri Jan 25, 2008 11:00 pm
I've edited your post above so you can see how it works (just edit your own post!).
For all others I show a copy of the code here with BBCode disabled:
[img]http://farm3.static.flickr.com/2028/2197356359_aff7f54a77_m.jpg[/img]
[url]http://www.flickr.com/photos/38912116@N00/2197356359/[/url]
[url=http://www.flickr.com/photos/38912116@N00/2197356359/][img]http://farm3.static.flickr.com/2028/2197356359_aff7f54a77_m.jpg[/img][/url]
PostPosted: Fri Jan 25, 2008 11:08 pm
Addendum:
How do you get that "http://farm3.static.flickr.com/..." address for the pic?
At Flickr you have to go to "all sizes", select the appropriate size of the image (e.g. "medium") and then copy the url that Flickr offers under "2. Grab the photo's URL:".
Do not use the code under option "1. Copy and paste this HTML into your webpage:" :!: That code doesn't work on this forum :shock:
 Post subject: Flickr
PostPosted: Fri Jan 25, 2008 11:09 pm
Ok I have created a flickr account it should come up under rsunsets59[img]flickrrsusets59.com[/img] or not! http://www.flickr.com/photos/23188996@N04/
----------------Edited by Thomas-----------------
This way:
Or better that way:
or even underlined:
PostPosted: Fri Jan 25, 2008 11:13 pm
Hmmm, that didn't work either!
If you click on "You" at Flickr, just copy the address directly without any tags into your post here!
Just like http://www.flickr.com/photos/38912116@N00/
That should work fine, and we should be able to at least find your account and can work from there...
 Post subject: flickr
PostPosted: Fri Jan 25, 2008 11:21 pm
I got most of it but it is not underlined in red how do i do that?
http://www.flickr.com/photos/23188996@N04/[/u]
PostPosted: Fri Jan 25, 2008 11:28 pm
Look at / edit your post above!
I've made the corrections...
PostPosted: Fri Jan 25, 2008 11:35 pm
Lets try this one more time and see if I ve got it... Hey! even thick headed old fa... like me can learn something new before I go any further I want to thank all of you for your help. Thanks Sunsets
