It is currently Sun Jan 22, 2017 12:33 pm
PostPosted: Thu Oct 28, 2010 6:08 pm
Hi all,
I got a question to those who use/have used MF lenses with aperture rings, or to those who have knowlegde about them.
When I use, for instance, my 35-70 zoom lens, at 35mm f/2,8 the exposure is 1/200. When I zoom in to 70 mm, and use the max. aperture too (that's f/4) the shutterspeed is 1/100, of course, BUT the aperture ring is set at f/2,8. Should that make diffrence if I set it to f/4? Of course not...
But it is! When I zoom in, and set the aperture at f/4 the exposuretime is 1/80, instead of 1/100.
Same applies to all my MF lenses, could anybody explain this?
My conclusion is that the max. aperture is slightly larger than written.
cheers
PostPosted: Thu Oct 28, 2010 8:12 pm
no,it won't make a difference.
the aperture won't change but the distance light has to travel to hit your sensor(or film) will.
the size of the glass in the camera is generally the factor.
PostPosted: Fri Oct 29, 2010 1:26 am
That's odd, there should be no difference!
Palak makes a good point, it's the amount of glass on the lens.
-Evan
- Ansel Adams
PostPosted: Fri Oct 29, 2010 6:21 am
That could be the case...
Thanks guys. :wink:
PostPosted: Fri Oct 29, 2010 7:40 am
But, guys, how could it be possible that the max. diaframga on 70 mm is f/4, and when I set the diafragma-ring to f/2,8 that I get a shorter exposure?
I mean, the 35-70 has a max. F of 2,8-4,0; so when @70mm the diafragma should be f/4, but I set the ring to 2,8 I get a shorter exposure.
Strange, isnt it?
PostPosted: Mon Nov 01, 2010 3:00 pm
Could anybody help?
PostPosted: Mon Nov 01, 2010 4:20 pm
decouple the lens, zoom to 70mm, look through it and twist the aperture ring?
PostPosted: Mon Nov 01, 2010 4:34 pm
And even then, the aperture closes!
@70mm it should be f/4, but when I turn the aperture dial to f/4 it closes slightly. That's confusing me :?
Users browsing this forum: Google [Bot] and 4 guests
