It is currently Sat Jan 21, 2017 4:49 am
PostPosted: Mon Jan 21, 2008 3:37 pm
Please forgive my ignorance and thanks in advance for your patience.
I'm upgrading my MacBook Pro 2.2GHz from 2GB to 4GB or ram. Right now I have 2GB of DDR2 SDRAM 667MHz.
My question is this: Will any DDR2 ram work for me or does it need to say DDR2 SDRAM 667MHz? I've seen DDR2 ram for sale, but it did not specifically say "SDRAM" on the box. Can I just assume it's SDRAM or is that a special type or ram?
Thanks to all the tech gurus for the help.
-steve
Leica M9, Nikon D300s, Leica X1, Canon S95, Zero Image 6x9
PostPosted: Mon Jan 21, 2008 5:13 pm
I'm not sure, but afair SR-RAM is stanard (at least for PC's), and u should therefore assume that it's SD even if they dont say so. That being said, its always a good idea to be sure, and i havent played with this stuff for a while, so wait for someone else to comment as well :p
Jake
 Post subject: Hi
PostPosted: Mon Jan 21, 2008 6:51 pm
I checked the tech specs and it says that you have 2 SO-Dimm PC2-5300 667Mhz DDR2 modules. If you have 2 installed that means that you have to buy 2 more but 2GB each.
You have to ask for the exact type, in this case SO-Dimm (SD) PC2-5300 667Mhz DDR2 NONECC UNBUFFERED 200 pin. If you are sure what it is, then there is no problem.
PostPosted: Mon Jan 21, 2008 9:06 pm
Hi, I'd recommend entering your model into the memory advisor tool at www.crucial.com (or www.crucial.com/uk for the Brist here!) - it'll reliably tell you what memory you can use, and then try and sell you some.
I use Crucial memory on all my systems - good value and no complaints...
(The high-performance guys may prefer Corsair though, but again I've had good results with Crucial's own Ballistix brand for extreme overclocking!)
PostPosted: Mon Jan 21, 2008 11:36 pm
I think all ram is SDRAM nowadays? Just make sure you get SO-DIMMs and not DIMMs.
PostPosted: Mon Jan 21, 2008 11:57 pm
Great! Thanks for all the help. I went to Crucial's site and they returned this after putting in all my laptop info:
4GB kit (2GBx2), 200-pin SODIMM, DDR2 PC2-5300 memory
So it does look like SDRAM is just standard these days. And thanks for the advice about ordering SODIMM chips instead of DIMMs.
-steve
PostPosted: Tue Jan 22, 2008 7:28 am
No complaints with Corsair here.
Zorro 8)
