It is currently Wed May 22, 2013 11:40 pm
 Post subject: White moth (DOF stack)
PostPosted: Tue Sep 21, 2010 1:14 am
I always aimed in the insect photos at detail in the compound eyes of the subjects, but considering they are only a small part of the subject most of the times to keep them in focus and the rest of the insect there is a need to high apertures, wich end in diffraction and motion blur and damage all the details at eyes. One viable solution if the subject is steady enough is to make two photos, one aimed at the eyes and other with longer DOF to cover all the insect, and make a "DOF stack" by layer work in post processing. The software I used was GIMP software. One third image, not present here, was used to address some highlight issues.
This set eve address some desired gear features discussed weeks ago in Canon forum, here in cameralabs.
White moth by Gustavo Mazzarollo, on Flickr
The entire image of the shoot at f/16, with Canon MP-E 65mm lens at 4x, wich result in a effective aperture of f/80, the diffraction vanish all the fine detail but the DOF cover almost the entire subject.
Without the worry about preserve fine detail was possible to expose to avoid losses to highlights and strong sharpening and strong noise reduction, but the compound eyes, the most important in this photo have suffered in detail and exposure adjusts.
White moth, long DOF by Gustavo Mazzarollo, on Flickr
Crop of the above shoot:
White moth, long DOF crop by Gustavo Mazzarollo, on Flickr
The entire image of the shoot at f/5, with Canon MP-E 65mm lens at 4x, wich result in a effective aperture of f/25, still into diffraction arena but much less than the usual compromisses of the apertures used at this magnification. The depth of field cover only the eyes and was possible to overexpose them for noiseless results in post processing. In post processing used very little sharpening and slight underxposed to be compatible with the image at f/16
The body of the insect lost most of the info in highlights and out of DOF parts, but will not be used for the final result.
White moth, short DOF, compound eye preserve by Gustavo Mazzarollo, on Flickr
White moth, short DOF, compound eye preserve crop by Gustavo Mazzarollo, on Flickr
Blog
http://www.gmazza.com
PostPosted: Sun Oct 17, 2010 10:58 pm
great shot, what equipment did you use
PostPosted: Tue Oct 19, 2010 1:23 am
These were taken with MP-E 65mm lens in the Canon T1i (500D) body.
Blog
