It is currently Sun May 26, 2013 8:55 am
PostPosted: Sat Sep 11, 2010 8:33 pm
Hey guys,
Can anyone comment on the below histograms? Basically, I converted an image to B+W with a slight sepia tone (for a more warm look), which means that it's not monochromatic, i.e. the image still has its colour channels.
Anyways, whenever I do the conversion, my histogram changes from a relatively smooth curve (the first image) to the spiked curve (second image). I don't think this is a posterized image, because as far as I understand, posterization is when gaps occur between vertical bars, however, I want to make sure that this assumption is correct before I send the images off to the printer.
Before
After
Thanks!
PostPosted: Sat Sep 11, 2010 8:54 pm
Does the conversion add some "grain" ?
Radu
Canon PowerShot S100
Canon580EXII
http://www.errre.net
PostPosted: Sat Sep 11, 2010 8:55 pm
Not that I noticed, even at 100%.
PostPosted: Sat Sep 11, 2010 9:07 pm
Then I have no more ideeas, sorry. But if the immage shows no psterization on your monitor I suppose there will be neither on your print.
Radu
Canon580EXII
PostPosted: Sat Sep 11, 2010 9:13 pm
I did use a plugin to do the conversion. Silver Efex, simulating film, but I did turn the grain up to about 500 grains per pixel (which should be practically unnoticeable) and I didn't visually see any additional grains during comparison.
You were thinking maybe the grains were causing the spikes?
PostPosted: Sat Sep 11, 2010 9:52 pm
Yes, but I must be wrong. It seems to be a residue from the conversion. More pixels fom a particular tone campared to de adiacent tones, I imagined it like grain.
Radu
Canon580EXII
PostPosted: Sat Sep 11, 2010 10:11 pm
It really is worrying though. Don't want to have to pay to get prints done over.
Found this, but not sure how credible a source this is, but from what he says, I should be in the clear.
http://www.ronbigelow.com/articles/posterization/posterization.htm
PostPosted: Sat Sep 11, 2010 10:27 pm
posterization in a histogram would be spikes that max out rather than a chunky histogram.
Posterized:
Normal:
Manfrotto 055CX3 + 496RC2
www.thomaslowe.com
PostPosted: Sat Sep 11, 2010 10:30 pm
So I should be fine then?
Beautiful shot by the way (even posterized :D)
PostPosted: Mon Sep 13, 2010 9:24 am
yes you're fine.
www.thomaslowe.com
PostPosted: Mon Sep 13, 2010 10:03 am
Did you shoot RAW? Raw tends to have less posterization when you start messing with the colors.
PostPosted: Mon Sep 13, 2010 6:55 pm
I did shoot RAW, but I did process the image in photoshop as a TIFF exported from Lightroom (16bit, 350 PPI, AdobeRGB).
