It is currently Sat May 25, 2013 7:23 pm
PostPosted: Sat Sep 11, 2010 6:43 am
I was planning on getting a 58mm ND filter and Uv filter for my 2 ef-s lenses and a step down ring to 52mm for my 50mm prime, but apparently that'll introduce a ton of vignetting is that true?
Check out: http://www.eagle1337.deviantart.com/
Camera: Canon Rebel T1i
Lens: Tokina 11-16mm f/2.8, Sigma 17-70mm OS DC HSM f/2.8-4, ef-s 18-55mm IS, ef-s 55-250mm IS. EF 50mm F/1.8
Tripod: Giottos MTL9351B with a MH 5001 head.
Bag: lowepro Slingshot 202 AW. Cards: Sandisk Ultra 2, Lexar MicroSDHC.
PostPosted: Sat Sep 11, 2010 8:27 am
Step up rings are used to fit a bigger size filter to the lens than native. This should not introduce vignetting.
Step down is used to fit a smaller filter to the lens than native. This will reduce the image circle produced by the lens, so has a significant risk of vignetting. Specifically, you might lose corners totally to some degree.
PostPosted: Sat Sep 11, 2010 12:16 pm
Ah so what I want to do is fine, I've just been calling it the wrong thing. I've been wanting to step down from a 58mm thread to 52. Now what concerns me more is the guy who wanted me to buy a step down ring from 52 to 58, not 58 to 52, as he's a "pro". I would have figured I would have been corrected on my miss hap, and he wouldn't want to sell my a 52 to 58m. Either way nothing was purchased.
PostPosted: Sat Sep 11, 2010 1:58 pm
No, you need is a step-UP ring from 52mm (lens thread's diameter) to 58mm (filter thread diameter).
http://www.amazon.com/gp/product/B0000A ... d_i=502394 is what you need.
PostPosted: Sat Sep 11, 2010 2:17 pm
well I gotta say reading comprehension sucks on no sleep. :lol:
PostPosted: Sat Sep 18, 2010 10:13 pm
again probably a dumb question but would going from a 77mm thread down like this: 77-72mm, 72-67mm, 67-62mm, 62-58mm, 58-55mm, 55-52mm cause vignetting or am I fine?
The step downs in question here.http://www.amazon.com/Fotodiox-Anodized-49-52mm-52-55mm-55-58mm/dp/B001G445Q4/ref=cm_cr_pr_product_top
Edit: I linked to the wrong ones orignally.
PostPosted: Sun Sep 19, 2010 1:31 am
Don't know, but you are probably better off using http://www.amazon.com/Adorama-Step-Up-A ... 172&sr=1-1
PostPosted: Sun Sep 19, 2010 1:40 am
i also have a 58mm too, that's why i was thinking of the kit one.
PostPosted: Sun Sep 19, 2010 7:58 am
As long as the filter size is bigger than the lens size, you'll probably be fine. Maybe in theory an ultra-wide lens would be hindered by an adapter ring combo if the rings don't spread out as fast as the lens field of view. I use a step up set myself, sometimes using 2 or 3 rings to get the filter onto a lens. Also consider looking on ebay for specific single adapters going directly from lens to filter sizes needed. They're really cheap from China.
The only problem I've come across with using multiple rings is sometimes it is very hard to separate them again.
PostPosted: Sun Sep 19, 2010 8:00 am
If it's a wide angle lens, you'll get vignetting. If it's a telephoto lens, probably not.
