It is currently Sat May 25, 2013 7:36 am
 Post subject: Raynox DCR-250
PostPosted: Sun Aug 29, 2010 11:07 am
Hi guys,
I just came across the Raynox DCR-250 lens.
I'm not really a macro photographer, but I like macro and don't want to carry another lens with me (and also, short on budget right now).
Does anyone use this lens? How it is?
I read that it's up to 67mm, so it won't fit my 17-40 (which is 77mm), but it can fit my 70-200 f/4. Do you have any experience with it on the 70-200?
Thanks
Canon EOS 50D, Canon EF 17-40L, Canon EF 70-200L f/4 IS and Canon SpeedLite 430EX
My picasa
PostPosted: Sun Aug 29, 2010 5:44 pm
Hi amitzil,
I have the Raynox DCR150 and DCR250. And I have used both on my 55-200mm lens.
Optically and price vs. performance-wise I have only praise for these lenses.
The DCR250 is "extreme" at 200mm and will give you a lot of magnification..the kind you might want for a close-up of a fly's eyes or something like that...not a whole flower, for example.
In my experience, I've found that the DCR150 is the one that I typically reach for , but if you're anything like our esteemed GMAZZA and want to get so close to a spider that you can see if it's happy or sad by it's facial expression, then maybe the DCR250 is for you.
As with all macro-photography, the challenge is to get the depth-of-field wide enough to cover the subject appropriately. So the lenses you put these Raynox attachments on doesn't have to be large-aperture lenses - you will most likely require the F-stop to be at F8 or even higher - F11, F16 or something like that - which means you need to have a lot of light on your subject. Sun or artificial lights. The reason I bring this up is that these higher F-stops are usually where most lenses perform at their best anyway, so that Raynoxes can turn any lens they fit into a well-performing macro lens in all but the most unusual circumstances.
Good luck with your choice!
Cheers :-)
PostPosted: Mon Aug 30, 2010 4:49 am
Hi LahLahSr,
Thanks for the info, it's very helpful. I didn't even know that there is also DCR150. I'll check it out. It sure looks nice and a great option to have a "cheap and lightweight" macro.
By the way, I'm aware of the DOF issue in macro, and I assumed that the aperture used is f/8 or lower. But if this is the case, why macro lenses usually have large aperture?
Thanks again
My picasa
PostPosted: Tue Sep 07, 2010 4:28 am
Hi amitzil,
that's a good question - I honestly don't know why macro/micro lenses are typically large-aperture. Maybe it's to make them overall more attractive - those lenses are also excellent portrait-lenses...60mm or 105mm are great portrait focal lengths.
The third one I think was taken with that Raynox on a 55-200mm lens.
..And the very last one was an experiement..it's taken with the DCR-250 @ 200mm to illustrate the crazy-think DOF and the magnification...almost abstract there..lol.
Cheers :-)
Here's two casual examples I found, using my Raynox DCR-150 on a Nikkor 50mm F1.8 AF-D lens. They are taken F11 and F5.6 and I have no complaints on the sharpness or color with these Raynoxes.
PostPosted: Tue Sep 07, 2010 5:54 am
On the aperture, I think it is to do with reducing effective aperture at high magnification.
The equation is effective aperture = physical aperture * (1+magnification)
So for a 1:1 macro lens, the effective aperture at maximum magnification is double that of the physical. Why is this important? The camera AF is typically rated to f/5.6, which happens to be double f/2.8 typical of most macro lenses.
PostPosted: Tue Sep 07, 2010 7:07 am
LahLahSr, these are nice pictures.
I ordered the DCR-250, it will take about a month until my friend will bring it to me from the US. Can't wait to try it on my 70-200...
popo, that's very interesting, I didn't know that... If this is the calculation of the effective aperture, it does make sense.
Also, I now remember that most cameras have AF extra sensitivity (or something) when using f/2.8 or faster lenses.
Thanks to you both
My picasa
