It is currently Wed May 22, 2013 8:48 am
 Post subject: Picture quality
PostPosted: Wed Jan 27, 2010 6:24 pm
Got some pictures printed at boots and some havent come out well, kinda like pixeley yet some are pin sharp? What could it be any ideas?
Nikon D90, MB-D80 Battery Grip
18-105mm f/3.5-5.6 VR Lens
Speedlight SB-600
Tamrac Expedition 5 Backpack
Sandisk Extreme 3 - 8gb
Vista Attaras Tripod
so far......
PostPosted: Wed Jan 27, 2010 6:31 pm
It's quite hard to know what you're talking about without any examples to illustrate your point. Perhaps you could point us to the photos that aren't turning out as expected?
PostPosted: Thu Jan 28, 2010 2:03 pm
Well i couldnt really show you becuase they have been printed and posting them up on the net wouldnt work because they look fine.
Its almost like the pictures arnt very sharp in detail.
Is it possible the printing machine at boots could have done some bad prints?
Speedlight SB-600
so far......
PostPosted: Fri Apr 23, 2010 3:31 am
Yes, it is possible that the machine in Boots was designed for good all round consumer results. There is usually a disclaimer (terms and conditions) that you are obliged to accept prior to submitting prints to the photolab, with most retailer services. The disclaimer states that you are not allowed to use the service for professional use (I guess that this is to prevent complaints towards results for larger wedding photos).
I asked on a similar thread about this, and Gordon reccomended using higher end photolabs like Metro and Photobox.
Canon EOS 500D
PostPosted: Mon Aug 16, 2010 12:56 pm
First of all calibrate your screen so it displays accurate colors.
You should at least print at 72DPI but for best results I recommend you use 300DPI.
Prints will loose a bit of saturation, contrast and sharpening so you should prepare the image for printing in photoshop (or whatever program you use).
Do this by using an unsharp mask to sharpen it slightly, improve contrast a bit and up the saturation a bit too.
It's a bit of trial and error. After printing a few pictures you'll find out what works and what doesn't.
PostPosted: Mon Oct 04, 2010 9:59 am
Hmm... It seems both mariewilliam1 and robinhood01 are spam accounts.
Ben
