It is currently Sat May 25, 2013 3:34 am
PostPosted: Fri Aug 13, 2010 3:00 pm
I managed to get some time to visit the National Memorial Arboretum in Central England while in the UK - this is a new area of designated parkland which is a place to honour those who have served in Armed Forces and Support Forces in conflicts and wars in the 20th and 21st centuries, excluding the First and Second World Wars.
In some areas it was sombre (for example seeing each and every UK serviceman that has died since World War II engraved on walls) but also is there to celebrate people that have served their country throughout the world.
As it is a new development, opened in the last few years, the trees are just starting to grow, and it will be interesting to see how the place develops in coming years.
Here are a few shots from my visit (the B&W first shot is a statue to celebrate the Berlin Airlift in 1949, where UK and US Air Forces airlifted millions of tonnes of food and produce into Berlin after it was segregated and then cut off by Soviet forces after WWII)
1.
2.
3.
4.
5.
6.
7.
8.
PostPosted: Fri Aug 13, 2010 4:15 pm
Nice set Phil,
I like the first eagle best.
Where are you off to (south east asia)
PostPosted: Fri Aug 13, 2010 4:45 pm
cheers Lowliferider - Bali in September... (woohoo!)
PostPosted: Sun Aug 15, 2010 4:59 am
Let me check my loto ticket and I'll join you in Indonesia.
Have a great trip (looking forward at your future post)
PostPosted: Mon Aug 16, 2010 3:47 am
Nice set Phil, I was looking at the exif on #2 as all your shots are crisp and sharp. I tried identical setting on my D40X with a 18-200 @24mm, aperture priority @F4, ISO 200. The speed calculated by the camera was 1/1000 which is less than half of your speed of 1/2500. The conditions were similar, bright blue sunny sky, even facing close to the sun I could not attain that speed on aperture priority, removing the UV filter only gave me 1/1250. Looks like the technology changed drastically from the D40X to the D90. I’m looking to make sharper images as I think mine lack this.
PostPosted: Mon Aug 16, 2010 6:27 am
4xxxx
Did you take the exposure compensation into consideration? I think I dialled in anything from -0.67 to -1.67 while shooting, as there were occasional breaks in the sunlight...
PostPosted: Mon Aug 16, 2010 6:29 am
4xxxx
The 24-70 helps as it's very sharp wide open and is stellar by F4. Also, a little unsharp mask in pp (around 40-50%) brings things out even more...
PostPosted: Tue Aug 17, 2010 12:14 am
Phil,
I put in the -EV. I Just had a thought, I may have a problem with the sensor. Thanks for the info and look forward to seeing more of your shots.
