I'm unfamiliar with that track, but if you believe the lighting will be great, or is outdoors during the day, you will not have any problems. On the other hand, if it's at night time, or inside, you might want to bring a 50mm f/1.8 or better in case there's not enough light. If you can afford a large aperture with long focal length, that'd definitely give you a bigger range to play with for your shutter speed.
Last thing you want is to need a 1 sec shutter speed, a tripod, and to have to tell the bikers to slow down because their images are coming out all blurry
