It is currently Fri Jan 20, 2017 4:32 pm
PostPosted: Mon Jul 19, 2010 6:05 am
I don't see them on the lenses I have looked at...
What is the, min shutter speed to NOT have shake at 10-24mm, at the hands of avg people?..
I remember there's a calculation with mm and times the number of something soemthing... to find the min shutter speed..Anyone know what I"m talking about?
Thanks =]
PostPosted: Mon Jul 19, 2010 6:47 am
There is the guideline of a shutter speed of 1/(focal_length * crop_factor) so 10mm on a typical canon would be 1/16s. BUT people can do better or worse than that guideline, and it does seem to break down for wide angles and close focusing.
The only way I'm aware of to get stabilisation on those types of lenses is to use a system which uses sensor shift. I don't know why it isn't put into ultra-wide lenses, possibly due to the reduced necessity, and possibly due to complexity.
Before anyone says it isn't needed, I can hand hold a 1 second exposure with IS on the E-P1 with 12.5mm f/1.3 lens fitted. It always give a potential advantage if present.
PostPosted: Mon Jul 19, 2010 6:51 am
Personally???
Yes, I would love Image Stabilization on ALL my lenses.. Why? For 3 reasons.
1. I have VERY shaky hands at times.
2. Low Light
3. At times where I cant fit a tripod, and it needs to be handheld, I like that extra feeling that my images will come out sharp.
:D
PostPosted: Mon Jul 19, 2010 7:40 am
I need stabilisation for street & journalism...or so I've thought. At the 1st big event that happened in my city this year,I took over 200 shots at F8 & speeds from 1/160 to 1/500 with the stabilisation set to OFF by mistake from a previous product shot experiment...not even one shot was not sharp. I was amazed. I have a steady hand,so this is the most important factor.
But stabilisation can really help in all of those moments when you need to do a photo really fast & you don't have time to steady your camera that well.
PostPosted: Mon Jul 19, 2010 10:00 am
There is a danger of relying on stabilisation over good technique. I would concentrate on the latter.
PostPosted: Mon Jul 19, 2010 11:35 am
Forgot to mention earlier, the formula I gave is only for prevention of camera shake, it does not do anything for subject movement for example.
Razvan, those shutter speeds are not eaxctly slow... unless you were using a long tele (300mm+?) I wouldn't expect there to be much problem.
Generally, stabilisation only really comes into serious play if you want to exceed that significantly. Technique only buys you so much.
PostPosted: Mon Jul 19, 2010 1:25 pm
I know there are not slow...but for someone without steady hands,it may be a problem
PostPosted: Mon Jul 19, 2010 1:43 pm
Stabilisation at shorter focal lengths is great for landscapes (you can close your aperture 2-3 stops without risking camera shake), but for people shots it's kind of useless, unless you want the blurry effect.
PostPosted: Mon Jul 19, 2010 2:04 pm
Most landscape photographers will have a tripod so IS for landscape is kinda useless IMO.
But its always useful for... I don't know.. If your tripod is moving.
Maybe you are on a boat. :lol:
PostPosted: Mon Jul 19, 2010 2:17 pm
If you're in a boat,maybe the 3-way Pentax stabilisation is the best choice :D
PostPosted: Mon Jul 19, 2010 4:27 pm
While hardcore landscape photographers might carry a tripod around with them, I'd say the average mixed interest photographer wont, and opportunities may be won or lost with IS. While it may not be necessary in a number of situations, to dismiss it all together is being extremely short sighted.
PostPosted: Mon Jul 19, 2010 9:13 pm
I meant if you do have a tripod (and use it) IS is pretty useless.
I can agree that if you don't then IS is better than no IS.
IS is IS SIS sissy ISIS..
PostPosted: Tue Jul 20, 2010 7:46 pm
Mind you the latest Nikkor 16-35mm for FX has VR image stabilization.
And rightly so!
I'd love to have stabilization for all my lenses and as that is not going to happen I'd love to see Nikon implement body-based IS as a complementary system for those lovely non-stabilized lenses like 50mm and 85mm primes, 14-24mm, PC-E Nikkors etc. But unfortunately that is also highly unlikely :cry:
I hate schlepping a tripod with me and a monopod gives only limited stabilization and shooting nature in dark woods at not so optimal light with a little dof at base ISO immediately brings you to the 1/4-1/30 sec range. And that is very prone to shake even with a 24mm or 35mm lens.
But I also agree with those saying you should practice hand-holding and not rely solely on the wonders of your IS!
__________________
Thomas (beware: Nikon-fanboy and moderator!) My Pictures, My Photography Blog
D300+assorted lenses
PostPosted: Tue Jul 20, 2010 7:56 pm
@agun
Agreed, but there are a lot of times i cannot use a tripod so VR is very useful. :D
PostPosted: Tue Jul 20, 2010 8:22 pm
This an example on how stabilisation can work out best in a bad lighted environment: http://www.flickr.com/photos/28103410@N ... 1/sizes/o/ & a 100% crop http://www.flickr.com/photos/28103410@N ... 4/sizes/o/ .
That was F/5.6,ISO 100 & 1/6 shutter speed,taken in a skate shop.
(I know it's not third-party-type stabilisation,but they should work the same)
