It is currently Sun Jan 22, 2017 12:31 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 14 posts ]
PostPosted: Tue Jun 01, 2010 5:47 pm
sdowden look away now!
SonyAlphaRumors rate this one highly, backed up with a known Sony patent and probably other info.
Phase AF video recording will push these right up in usability for normal people, while remaining largely DSLR like other than no having an optical viewfinder.
Other claims:
Alpha mount
Two models A55 (1080), A33 (720).
Small body like current crop DSLR models
"Cheap"
My thoughts:
* are they going to bring out many more silent focus lenses? I'm not sure people will want to carry round external mics or separate recording devices if this is targeted at non-pro levels.
* No OVF implies EVF
* is the AF system going to be optimised for video? The typical small scattering of points isn't going to be enough, will they bump up the AF point number significantly for better coverage?
* this appears to be yet another new line in addition to existing DSLRs and NEX. Do they have the will and resources to push DSLRs forward on the higher end?
PostPosted: Tue Jun 01, 2010 5:58 pm
I think (read hope) they use a secondary sensor for the video (as they have with LV on the a550).
PostPosted: Tue Jun 01, 2010 6:02 pm
Check the link, the main sensor will be used for recording, with a fixed semi-silvered mirror allowing the full time AF. Do not look at this as replacing the conventional SLR which I think will stick around for a lot longer yet, but opening a new area for SLR form factor video.
PostPosted: Wed Jun 02, 2010 9:38 am
Could be interesting for video. I'm not too sure about the pellicle mirror though. Will it decrease the amount of light that gets to the sensor? If so, to what extend?
Using a mirror like this would help for video, but if it does decrease the amount of light that gets to the sensor, the mirror should be able to flip up when taking photos, even if it's a setting that can be turned an and off.
PostPosted: Wed Jun 02, 2010 11:09 am
The speculation is there will be a fraction of a stop of light loss, so in the grand scheme of things that isn't significant unless you're already bumping the ISO right up.
PostPosted: Wed Jun 02, 2010 11:31 am
I read you lose about 1/3 stop of light. Not too bad I guess, but it will make a difference in the low light I like to shoot in. Still, I'd be quite happy to have a pellicle mirror in a second body...
PostPosted: Tue Jun 08, 2010 1:31 pm
are we going to get a full frame that will shoot 10fps for us sport shooters?
Stuff the video, if I wanted to shoot video I'll buy a video camera, I want a pro level dSLR from sony.
PostPosted: Tue Jun 15, 2010 5:28 pm
You can flip up the mirror to avoid light loss but the phase detection would not work but there should be some other kind of AF system to work with. I would not worry about the light loss, the only thing which is bothering me is the brightness of the viewfinder. although it would have an electronic viewfinder.
PostPosted: Thu Jul 15, 2010 10:52 am
http://www.digitaltrends.com/photograph ... /?news=123
Might be he better way to go.
Leave the dSLR's to do what they're great at, taking photos, if people want SLR type dof and interchangeable lenses they can buy this camera.
PostPosted: Thu Jul 15, 2010 11:45 am
A camcorder format is useful if you want to carry it and use it like one, but many people would probably still like a DSLR first and the potential to have similar video.
PostPosted: Thu Jul 29, 2010 5:15 pm
SonyAlphaRumors have posted more claimed specs with a high rating.
1) A55 (translucent) 16MP 10FPS EVF-1.44M 1.1X magnification 95% AVCHD full hd
2) A33 (translucent) 14MP 7FPS EVF-1.44M 1.1X magnification 95% AVCHD full hd
3) A560 14MP 7FPS MF recording AVCHD full hd
4) A580 16MP 7FPS MF recording AVCHD full hd
Given the A550 has reportedly been marked as discontinued, the updated models are not much of a surprise.
The two new models are the interesting one. Already some traditional photographers are foaming at the mouth over the EVF, but they're missing the point those models are something new and more video centric, although by no means excluding the photo capability. It just will be a little different. While I could speculate more, I think I'd wait and see what they really do.
PostPosted: Fri Jul 30, 2010 10:42 am
As I've already said elsewhere, I'm curious to see how good the EVF/OVF is going to be. It's hard to beat a decent OVF with a pentaprism...and I'm not even mentioning (ok, I am now...) the 'life expectancy' to put it that way, of the rumoured OLED EVF.
I read the other day (on Wiki) that there seems to be a problem with blue colours and their lifespan. If the blue thingies on it need to be replaced, it needs a completely new EVF, I'd say.
http://en.wikipedia.org/wiki/OLED#Disadvantages
My photos on Flickr...
Last edited by Joris Van den Berghe on Fri Jul 30, 2010 1:52 pm, edited 1 time in total.
PostPosted: Fri Jul 30, 2010 11:09 am
I don't know how accurate or up to date that info is, as OLED is a relatively new technology, improvements are still going to be relatively large in the short term. Still, even at the claimed "8 hours a day for 5 years" life, that's going to be more than enough for non-pro use.
PostPosted: Tue Aug 24, 2010 4:51 am
Hi everyone, official sticky threads now started, so these ones now locked - cheers!
Users browsing this forum: Bing [Bot] and 3 guests
