It is currently Sun May 19, 2013 4:19 pm
 Post subject: UV filters...
PostPosted: Sun Jan 13, 2008 5:42 pm
'what are the advantages???
Cheers!
PostPosted: Sun Jan 13, 2008 8:44 pm
DSLRs have UV filters built into them, so the only real reason is to stop you getting scratches or dirt on your lens. After all, it's a lot cheaper to replace a UV filter than a whole lens. Try to get a multicoated one however, or you may get lens flare in your pictures.
Olympus E-510 | ED 14-42mm 1:3.5-5.6 | ED 40-150mm 1:4.0-5.6 | 35mm 1:3.5 Macro | Giottos MTL8361B & MH-5001 3-way head | Lowepro Orion Trekker II bag
http://www.calummacnab.com
PostPosted: Thu Jan 31, 2008 12:58 am
So would you say the cheapest Tiffen of Hoya Multicoated UV filter should be good enough for a beginner? I see that the coatings are what seem to add to the price. Any suggestions for which one?
Canon 40D kit Lens 28-135mm IS, Canon 50mm F/1.8, 10-22mm, 100 2.8 macro, 580 Ex.
PostPosted: Thu Jan 31, 2008 1:25 am
Remember that even a top-end filter will have some impact on ultimate image quality - any extra element will - BUT this is the accpetable compromise for the protection for most people.
PostPosted: Thu Jan 31, 2008 10:58 pm
well, the advantages of having one is very helpfull, when taking say pictures of a reflection on water and its too bright you can use a polarising filter, using a UV filter is good for low light or if you want very nice bright primary colours etc i would recomend buying one or two will help you out in alot of sticky situations
