It is currently Mon Jan 23, 2017 8:54 am
PostPosted: Thu Jun 17, 2010 8:27 am
Is there a hack or something that enables rear shutter sync with a third party full manual flash like vivitar or sunpack?
thanks already.
PostPosted: Mon Jun 21, 2010 4:19 am
bump
PostPosted: Sun Jun 27, 2010 8:06 am
Bump Bump...
Please guys some help please...
PostPosted: Sun Jun 27, 2010 9:51 am
Just set it in camera, it's the camera's job to send out the trigger pulse at the right time. ;)
PostPosted: Mon Jun 28, 2010 4:53 am
Thats the whole issue. You see, if you have a third party not e-ttl compatible flash on the camera, it will no longer show the flash menu. Did you understand what I mean.
Its not possible to set it in the camera directly, there must be a way around.
PostPosted: Mon Jun 28, 2010 11:17 am
I understand, but it should still be possible. All your flash does is....eh...flash, when it receives a pulse from the camera hotshoe. It might work if you have a PC connection cable.
Or just set your synchronisation to rear curtain before you mount the flash, that might work.
PostPosted: Mon Jun 28, 2010 11:29 am
The 1000D i have, is a cheapo, it does not have a PC sync connectivity.
But, I should try enabling IInd shutter sync before mounting the flash, that might work. :idea:
why did'nt that occure to me earlier. I'll try that in the evening, and will come back to you if it works. Thanks.
PostPosted: Tue Jun 29, 2010 8:47 am
Sorry dude, but that dosent work either. I believe there should be some firmware hack to do this. CHDK you know.
PostPosted: Tue Jun 29, 2010 2:48 pm
Maybe it will work with a hotshoe -> PC -> hotshoe connection?
PostPosted: Tue Jun 29, 2010 2:58 pm
Nada... tried that too! :(
