It is currently Thu Jun 20, 2013 8:39 am
PostPosted: Sun Jun 27, 2010 7:39 am
Hi,
I just found several wide angle lenses that you cna screw at the end of your lens. They called them 0,45 x wide angle.
What does that mean? The focal lenght X 0,45?
IF that's true, you can make from your old EF 28mm (what's on a crop factor less wide of course) a 28x0,45x1,6 lens?
Here a link btw: http://www.focalprice.com/DI532B/Digita ... Black.html
PostPosted: Sun Jun 27, 2010 9:23 am
I wouldnt touch one of these.
It looks like as you say, you add it to a regular wide angle lens to make it an ultra wide angle, with a focal length of 0.45 multiplied by the actual focal length.
Id hate to see what it would do to the image quality.
PostPosted: Sun Jun 27, 2010 9:54 am
Whilst I have no experience with them, you can be sure to get poor performance (sharpness, flare, contrast), and probably a vignetted image.
PostPosted: Sun Jun 27, 2010 9:59 am
I love some of the sales jargon they throw at you. Such as:
Macro
Infrared compatible
Optimized for mega pixel photography
High definition
I got a similar one for smaller form factor. It was... interesting. Build quality was a nice surprise, with aluminium body and anti-reflection coated optics. Image sharpness was ok, yes it did get wider, but the image itself was reduced quite a bit. I guess I should give it a more detailed test and report back as an indication.
Oh, the macro part is the lens allows closer focus than without.
Edit: Now I remember why I didn't use it... the one I got only fits one of my lenses, and the AF motor isn't strong enough to turn the lens with the additional lens on the front.
PostPosted: Sun Jun 27, 2010 10:24 am
Thanks, I know it shouldnt have the best quality, and I had to laugh when I read about the High Definition :)
I asked myself this because I want to use my old lenses with an adapter on a new DSLR, but, 28mm was wide on a 35mm camera, but now it isnt.
IF the quality isnt there, itll be a throw of money I could have invested in a better lens.
PostPosted: Sun Jun 27, 2010 1:57 pm
Using a similar product for my camcorder and it works a treat for those times when you can't fit everything you'd want in the picture. It has a bit too much fish-eye effect for my liking to be able to leave it on for everything though. But I don't think it'd be great to use with a still camera.
This company makes some rather high quality wide-angle lenses though http://www.raynox.com/
Canon 500D, 18-55mm IS, 55-200mm IS, Nissin Di622
PostPosted: Sun Jun 27, 2010 3:11 pm
Raynox is supposed to be pretty decent from what I've heard. Als keep in mind that these things screw on, so it's not one size fits all!
PostPosted: Sun Jun 27, 2010 4:45 pm
Indeed, the good thing with Raynox is that they supply adapter rings.
Sadly the one I have is not a Raynox...
