It is currently Thu May 23, 2013 9:52 am
PostPosted: Tue Jun 01, 2010 11:45 pm
Guys
Can someone please explain when I would use the 5D MKII internal wireless flash settings? I have it disabled yet my 580EX II can trigger an external Yongnuo speedlight.
Just a bit stuck on its use...
Thanks
PostPosted: Wed Jun 02, 2010 8:47 am
I'd assume the yongnuo is a "dumb" flash, meaning it flashes when it sees a flash. (slave flash)?
PostPosted: Wed Jun 02, 2010 9:10 am
Yes that is correct slave flash. Anyone able to answer about the 5D wireless question?
PostPosted: Wed Jun 02, 2010 6:12 pm
Well, that flash will go off whenever it sees a flash of light. However, if you use the built-in 5D wireless flash with a compatible flash, you can also make it send the correct exposure value, so the flash will fire at the appropriate power.
PostPosted: Sun Jun 13, 2010 11:53 am
Ah so the built in wireless section will allow you to set power ratios to compatible flash guns. Cheers.
PostPosted: Tue Jul 20, 2010 10:22 pm
the internal wireless flash system is for controlling 430ex flashes.
Master - Slave.
Mark Osborne
My life through an iPhone
