It is currently Wed Jun 19, 2013 7:07 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sat Apr 10, 2010 12:38 pm
For a cheap long lens I'd say one of those F/8 500mm mirror lenses would be a better choice than a scope.
PostPosted: Sat Apr 10, 2010 12:53 pm
A mirror lens is essentially the same as a similar construction scope, just a small one with a camera mount on it.
PostPosted: Sat Apr 10, 2010 1:23 pm
I know, but the 500mm makes it easier to steady. Same for the F/8, which also means less diffraction 8)
PostPosted: Sun May 30, 2010 6:24 pm
I got a question about the motor: Will it track stars correctly in 2 dimensions, or does the motor only move to the side?
PostPosted: Sun May 30, 2010 6:41 pm
It tracks in two dimensions, and the tripod comes with a wedge built in so you can set it up equatorial style and eliminate rotation too.
PostPosted: Thu Jun 03, 2010 2:00 pm
So itll track the stars exactly?
Thanks popo;)
PostPosted: Thu Jun 03, 2010 4:28 pm
It should track good enough, but personally I'm lazy so never got it quite perfect...
