It is currently Fri May 24, 2013 4:47 pm
 Post subject: New Card for Rebel
PostPosted: Tue Mar 02, 2010 2:53 pm
Hello,
I want to upgrade the memory card for Canon 400D. I have been using a 1GB Kinston CF card.. I do not have further details about this card.
I shoot mostly in RAW so I feel I need to get a faster card which has more capacity (min of 2 gb).
Does Canon 400D support bigger capacity cards >2gb?
What is the difference between CF card and SD card?
Please suggest me.
Phani Kumar
60mm Refractor,
150mm Newtanion Reflector,
18-55 mm Kit Lens, 55-250mm, M42 MC Helios 77M-4 50mm F1.8
Canon 400D.
http://www.flickr.com/photos/phani_astronomy/
PostPosted: Tue Mar 02, 2010 3:02 pm
I'm pretty sure it supports more than 2 GB's, but I can't back it up (check your manual).
As far as speed goes: I wouldn't go higher than a Sandisk Ultra II, above that I think the camera will bottleneck and you will have wasted your money. Class 4 should be sufficient.
PostPosted: Tue Mar 02, 2010 3:45 pm
The manual seems to have limited information it says:
"either of Type I or Type II cards can be inserted in the camera. The cam isalso compatible with Microdrive (hard disk-type) and CF cards with 2GB or higher capacity".
what are these Type I and Type II and CF cards different for SD cards??
Phani Kumar
60mm Refractor,
Canon 400D.
PostPosted: Tue Mar 02, 2010 4:03 pm
I don't know, but the "CF cards with 2GB or higher capacity" sounds like you can fit any card in there.
PostPosted: Tue Mar 02, 2010 5:36 pm
Type I and Type II refer to physical size (thickness). I'm also pretty sure it'll support any capacity.
If cost is not a major hurdle, the new Sandisk Extreme is the one I'd pick. It's faster than Extreme IV, while similar in cost to Extreme III. Having said that, it doesn't seem to be available in lower capacities. I do agree with Cirtuspers that it is unlikely your camera will make use of the full speed, but if you have a suitable card reader it will transfer to computer faster, plus gives you a degree of future potential should you upgrade bodies.
On the value end, it does look like the Ultra II has now been replaced by the Ultra (30MB/s). Sandisk don't make their names easy do they? I think that's the same speed rating as the Extreme III which again should be fast enough not to limit the camera.
PostPosted: Thu Mar 04, 2010 4:43 am
Thanks...
Ok then i will check for the Sandisk Extreme II or the newly lunched Ultra (30MB/s)
Phani Kumar
60mm Refractor,
Canon 400D.
PostPosted: Tue Apr 20, 2010 9:44 am
I have a kingston 16GB in my 400Dks like a charm...fast too!
Gear: Canon EOS 400D | EF-S 18-55mm | EF-S 18-200mm IS | Metz 36 AF-4c flash | Cullmann 52013 tripod
Dreamland: Canon EF 50mm F1.4 USM
PostPosted: Fri May 14, 2010 6:03 pm
The 400d doesnt take SD cards?
PostPosted: Sat May 15, 2010 1:00 am
@Ruben123
Nope, only CF
http://www.AnderssonPhoto.com
