It is currently Wed Jun 19, 2013 2:53 pm
PostPosted: Tue Apr 27, 2010 12:48 am
MB : Asus P6T-SE
CPU : Intel Core i7 930 D0 2.80 Ghz
RAM : Kingston 3x2g DDR3-1086mhz
HDD : Western Digital 640 Go Black, 32 Mo Cache, 7200 tr/mn, Dual Processor
GPU : Sapphire HD5750 1Gigs DDR5
PSU : Antec True Power 750 Watts
Souris : Logitech G5 V2
Boitier : Thermaltake V3 Black Edition
Écran : Asus VW266H 25.5IN 2ms 1920X1200 20000:1 USB Hub HDMI Speake
CD/DVD : LG 20x Lightscribe
Like you can see, it did cost me all my savings ive made for a year, and Ive tried to spend the big bucks on the monitor !
What do you think ? Thanks :)
Canon Rebel Xti (400D), EF-S 18-55, 50mm f/1.8, Sandisk Extreme III 2gb.
Http://cr4zyh3ad.sisimple.ca
PostPosted: Tue Apr 27, 2010 12:31 pm
Looks good!
PostPosted: Tue Apr 27, 2010 10:05 pm
Don't think the monitor is worth it as it'll have a TN panel, so if you're really concerned about colour correctness, it won't be all that. Try to find an IPS based display instead, or one with an MVA/PVA panel, as they're all far superior to TN panels when it comes to colour correctness as TN panels are only 6-bit, while the other types are 8-bit or in some rare cases, even 10-bit (if you use DisplayPort).
The only models I can find for about the same money as that Asus display is the ViewSonic VP2365wb and the Samsung SyncMaster F2380, both of which are 23-inch models with 1920x1080 resolution.
Although, if you can stretch your budget a little bit, the NEC MultiSync EA231WMi seems to be a far superior model http://www.bit-tech.net/hardware/monito ... ea231wmi/1
Canon 500D, 18-55mm IS, 55-200mm IS, Nissin Di622
PostPosted: Tue Apr 27, 2010 10:40 pm
I wouldn't have bothered with Tri-channel configuration, very little gain.
You might also want to look into the new AMD Hex-core CPU.
PostPosted: Wed Apr 28, 2010 5:15 pm
Well a few weeks back I had to upgrade myself. I wanted to edit full HD video so I took the fastest CPU I could get with a reasonable price tag. Clearly the best value high performance CPU today is the Intel Core i5 750, just take a look here:
http://www.anandtech.com/show/2832
The price is VERY low and it's performance is often better than the Intel Core i7 920 and if you OC it, you should be able to get some 3,4 GHz on air (4+ on water).
PostPosted: Mon May 03, 2010 9:21 am
Nice!
Graham
PostPosted: Mon May 03, 2010 9:46 am
I would also stick to a Core I5 (price/performance) and do you really need a 750W PSU ?
Looks like a bit of an overkill to me.
My photostream
PostPosted: Mon May 03, 2010 11:53 am
Swap the power supply for either a Corsair or Seasonic, and you're good to go. If it's for video encoding etc, go i7 (you get four extra virtual cores - hyperthreading), if it's for photo editing, go for an i5.
PostPosted: Mon May 17, 2010 5:52 pm
That 1 hard drive should get looked at.
Faster drives for the OS, and ones with large storage and fast sequential read/writes (i.e. 500GB per platter drives, Samsung F3 1TB's are good, as are WD 2TB Black (64MB Cache)
Remember you can use RAID for performance/redundancy but always keep a backup seperate
- Also, dunno what its worth to ya, but I find I use a good 3-4GB of ram with just Chrome, iTunes, MSN, Tweetdeck, Steam, Word and Explorer open. Blast open Photoshop AND Lightroom, you're crawling. I dunno if its a good time to buy RAM atm, but I'm wishing i went for 12GB when I built mine just over 15 month ago.
MY FLICKR!
