It is currently Sun Jan 22, 2017 6:34 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Wed Apr 07, 2010 4:33 pm
I can't remember exactly now as it was quite a time ago, but I think it was around £400 maybe (the scope and mount comes together).
PostPosted: Thu Apr 08, 2010 10:17 am
popo wrote:
At the time I think it was £340 with computerised mount.
Ruben123 wrote:
Uhm, how much did you pay for the motorised mount+scope?
Something isn't working here.... :?
PostPosted: Thu Apr 08, 2010 11:21 am
Looks like my memory wasn't working either. At least I got the digit 4 in there :P
PostPosted: Thu Apr 08, 2010 4:58 pm
I'd like to see some pictures, the full picture and not 100% crops.
I'm curious how they look.
PostPosted: Fri Apr 09, 2010 1:19 pm
If you need a tad more resolution you could always re-mortgage your house and go for the canon 1200mm f5.6, add a 2x tc and you got one big scope. :D
PostPosted: Fri Apr 09, 2010 5:03 pm
Tomek, I'll have to dig some out...
darragh, in astronomical terms, I think dedicated scopes would give more performance for much less cost. The lens would have AF, but that isn't really needed for sky work. Roughly speaking, assuming the optics are of sufficient quality, the resolution is limited by diffraction, which eventually comes down to how big it is on the front. 1200mm f/5.6 is only just over 8 inches. A 12 inch dobsonian can be had for less than a 7D body, and a 12 inch Ritchey-Chrétien with mount is less than a 1Ds3.
PostPosted: Fri Apr 09, 2010 5:47 pm
Some samples... the first 5 are camera jpeg resized only with no further processing.
A thin moon... taken with camera at scope prime focus.
From same set as above, but this time using a 2x barlow for effectively 2650mm f/26. Even scaled down here you can see diffraction softening. It is still worth it
This is what the contrast looks like when the sky was still relatively light.
As above + 2x barlow again.
To give an idea of the size of the moon relative to focal length. Note the moon varies in distance, and therefore size from the earth. When it is close, it is too big to fit in a single shot on 1.6x crop sensor. Here it only just fits.
Also check out the best moon thread where I have posted two other examples. One shows the best resolution I ever got from the scope, the other is when I went for colour cleanness. Both of those involved processing.
And finally, my best planetary attempts with a DSLR:
Jupiter -
2650mm f/26 1/10s ISO400, 7 shots stacked
Saturn - 2650mm, f/26, 1/13s, ISO1600, up to 25 shots stacked
PostPosted: Fri Apr 09, 2010 6:07 pm
So, Popo, you have a 5D, which is full frame, right?
If Diffraction is your main issue, wouldn't mounting the 5D help? The larger sensor size would mean less diffraction?
PostPosted: Fri Apr 09, 2010 6:24 pm
This is no different than with photographic lenses. While bigger pixels (regardless of sensor size) will be diffraction limited later, a bigger sensor gives you get a bigger field of view so need more focal length to get the equivalent detail. For a constant physical aperture typical of most scopes, you trade focal length and photographic aperture so it works out about the same. Fundamentally, need bigger scope.
That reminds me, I wanted to try the 5D to see what the image circle of the scope output is like...
Edit: here's a test shot on the 5D, taken with the rear adapter (not eyepiece adapter).
Not bad, covers most of the frame.
PostPosted: Fri Apr 09, 2010 10:10 pm
Those planetary shots are pretty good!
What kind of barlow are you using?
PostPosted: Fri Apr 09, 2010 10:32 pm
I have the Celestron X-Cel ED barlow. Not though any particular choice other than it seemed to be above average construction and on sale when I got it.
PostPosted: Sat Apr 10, 2010 11:19 am
You could use the tracker to get nebulae shots. :o
PostPosted: Sat Apr 10, 2010 11:47 am
Thanks for stating the blindingly obvious.
PostPosted: Sat Apr 10, 2010 12:06 pm
Nice moon pics!
But it seems that moon pics are the only thing you can do with this lens.
I guess it's not really agile enough to go into the wild and take animal/bird pictures with.
PostPosted: Sat Apr 10, 2010 12:12 pm
It's not practical for terrestrial stuff. 1325mm f/13 is incredibly long and slow. You'll need a fast shutter aided by high ISO, and a stable platform. Plus, it is manual focus. Also, while it can focus close, at typical working distances even the air quality will impact the final result. You can see heat haze ripples for example, and reducing contrast as you focus further.
So it is not impossible, but unless you're photographing distant stationary subjects in good conditions, it isn't really practical.
This scope is primarily sold for night sky observation where these factors are not so significant a limitation.
