It is currently Fri May 24, 2013 8:21 pm
 Post subject: aperture FZ28
PostPosted: Sat Mar 27, 2010 2:38 pm
Hi all,
The minimum aperture (A) of my FZ28 is F/8
Isn't that the same as F/22 on a DSLR? So yes, what about F/4.5 on my panny, F/2.8 etc?
Question two: The min. A of my panny is F/8 as mentioned, but: when recording videos the min. A is F>13 (not had any higher)
How could this happen? When in M/A mode I could choose a higher number than 8, when in videomode is selects F/13?!
Thanks;)
PostPosted: Mon Mar 29, 2010 1:33 am
Hi,
Answer to question 1:
To my knowledge, the minimum aperture is f/8 at wide angle, but can go to f/11 at max telephoto. And f/8 on your camera should be equivalent to f/8 only on a dslr or full frame camera, since I believe you already have the equivalent value.
To question 2, I don't have a ready answer, but hopefully your manual may be of some help....
Jinay.
PostPosted: Mon Mar 29, 2010 9:26 am
Hi Ruben,
Given that a camera's f-number is just the measured focal length of a lens divided by the diameter of the entrance pupil there is no "equivalent" value for a DSLR. f/8 is f/8 regardless of the size of the sensor behind the lens.
But things get a little muddier in practice because of diffraction and depth of field. Your FZ28 has an effective crop factor of 5.625, obtained by dividing the 35mm equivalent focal lengths of your lens by the actual focal lengths. Both figures are given in the camera's specifications. So compared to a DSLR with the same pixel count as the FZ28 and a crop factor of, say, 1.5 the f-number needed to give the same DoF when both cameras are zoomed in to show the same angle of view is different by a factor of 5.625/1.5 = 3.75. So if the DSLR was shooting at f/11 for good DoF the FZ28 only needs to be stopped down to f/2.9. :shock:
Just as well because with the very high pixel density typical of its class the FZ28 needs to work near these sort of apertures to be sure that diffraction from the lens doesn't soften the image. The problems start if you want a shallow DoF on the FZ28, of course, because the lens aperture just can't go wide enough. I explored some of the trade-offs in my post Full-frame Sensors Are Better - Fact or Fiction?. The principles involved are equally valid when comparing the sensors in compacts or superzooms with DSLRs.
As for your f/13 while shooting video, I can see no mention of it in the manual. But my understanding is that when shooting at the low resolutions, compared to stills, of video the camera "bins" pixels together so each "pixel" on the video takes information from several pixels on the sensor. That means that the diffraction softening I mentioned doesn't kick in nearly so quickly so it would be reasonable for the camera to be able to stop the lens down further than usual. Maybe the iris can physically reach f/13 but is prevented from doing so unless video is being shot. If so it's a shame the fact isn't mentioned in the manual but I doubt many users would ever be aware of the fact.
PostPosted: Mon Mar 29, 2010 2:05 pm
Thanks Bob for explaining :)
That is really clear, in the future Im buying a dslr, because a week after buying my FZ28, I decided to use my cam. for astrophotography. Argh.
Thanksfully it has a max. exposure of 60 sec, and with several programs Im able to lower the noise.
Thanks again,
PostPosted: Tue Mar 30, 2010 1:58 pm
Maybe there are some FZ38/35 owners those can check it in Aperture Priority on their camera? As far as I know the FZ38 has a manual movie mode..
PostPosted: Thu Apr 01, 2010 2:56 pm
Hi Bob,
I read the link about full frame vs cropped sensors and it provided a very interesting read! (At least as far as my knowledge supported!) However, I do have some questions:
1. I understood that though the f-numbers are same on a full frame and cropped sensor, the depth of field can vary. Am I correct?
2. I would like to consider a 1/2.33" sensor against a full frame one, simply because they are most common in p&s. So, an f/8 aperture will give the same effect of a f/(8*5.625) aperture on a full frame? Does the same calculation apply to the entire aperture range?
3. If the above is true, does that mean that f/2.8, which is the biggest aperture on most p&s will give more back to front sharpness than a full frame f/2.8? Is that the reason that larger frame cameras are known for the wonderful background blurring effects which are hard to get on small sensor cameras?
Thanks in advance,
Jinay.
P.S. Now I believe Angel-slo was right in saying you got your theories perfect! Fantastic explanation, man!
PostPosted: Fri Apr 02, 2010 11:42 am
because of the bigger sensor you get a smaller DoF. For instance, for 2.8 on a p&s, you get the same DoF with 5.0 on a dslr. that's why dslrs can take more blurry backgrounds. However, I can say you, with my FZ28 with macro glass I can make macro shots of a fly that's only the eyes are sharp.
PostPosted: Sat Apr 03, 2010 1:23 am
Hi,
Ruben, I didn't understand the calculation of 2.8 on p&s to f5.0 on dslr. What is the formula to use?
Thanks,
Jinay.
PostPosted: Sat Apr 03, 2010 7:20 am
Hi, there isnt a formula :lol:
the only thing you've to understand is: a bigger sensor means smaller dept of field.
a p&s has a small sensor (so: great DoF)
a dslr has a big sensor (so: small DoF)
I know how to explain it in Dutch, but my English is not very good, Ill give a try.
When using F/2.8 on a p&s you get a small DoF
When using F/2.8 on a dslr you get a smaller DoF because of the bigger sensor. you understand this?
When closing the aperture on a dslr to, let's say, F/5.6, you get a bigger DoF, BUT, not as big when using a compact when using F/5.6
So, I hope Im right, the aperture is almost the same (however: when my lumix is set to 2.8 is has a much smaller iris when I set my rokkor-w to f5.6, anyone could explain this me?) But, because of the bigger sensor, you have to close the aperture for getting the same effect.
This is however almost never a problem: many people buy dslrs because of getting a small DoF!
PostPosted: Sun Apr 04, 2010 3:17 am
Hi,
Thanks for the answer, but I was wondering how you came to the f2.8 on a p&s is same as f5.0 on dslr in terms of DoF? What is the sensor size you have been considering?
Thanks in advance,
Jinay.
PostPosted: Sun Apr 04, 2010 6:12 am
the sensor of a dslr is almost (correct me if Im wrong) 5X as big as the lumix'.
I dont know exactly of 5.0 the same is as 2.8, 5.6 could also be the same.
I dont own (yet) a dslr, so it's hard for me to explain ;)
