It is currently Sat May 18, 2013 6:16 pm
PostPosted: Sat Mar 27, 2010 9:33 am
I received this week my repaired DA* 50-135mm lens. The SDM motor had to be changed. :(
Result is, AF has never been so fast. :)
I hope I'm going to enjoy this lens now for a long time with no more problems.
Best regards,
--- rei_vilo
reivilophotography.weebly.com
PostPosted: Mon Mar 29, 2010 6:45 am
Is it noticeably faster, or is it just psychological? :)
I've found the 50-135mm to be not as fast as my Sigma 70-200mm, though it's really really accurate. It's so accurate and sharp it makes your eyes bleed.
PhilipGoh.com
PostPosted: Thu Apr 08, 2010 9:48 am
Bonjour,
Sunday was sunny so I went out to test my repaired lens.
  • No surprise, image quality is there.
  • Big surprise, the SDM AF is really fast, faster than I could remember when I used this lens when I bought it. The lens focuses on a snap. I've never experienced that speed on that lens before.
It's hard to say whether it is psychological. The fact is, my 50-135mm used to be noticeably slower than the 16-50 and the 60-250. Now, it's on par.
Check for more here.
Speed: 1/400 s
Aperture: 4.0
Focal: 50mm
Speed: 1/320 s
Aperture: 4.0
Focal: 135mm
--- rei_vilo
PostPosted: Fri Apr 16, 2010 5:13 pm
Bonjour,
I wrote to Pentax France about the SDM motor failure, asking whether there was a problem with the first manufactured lenses.
My DA* 50-135 lens was one of the first ones available in France. The serial number of my lens starts with 900xxxx.
Although I mentioned that serial number in my letter, Pentax France didn't consider my specific case but stated that
Quote:
Despite all the fuss done on forums, SDM failures are not considered as a hidden defect.
and
Quote:
Lenses should be assessed on a one-by-one case.
Pentax France didn't go further on its answer. Alas, the repair department didn't provide any explanation for the failure of my lens.
Once again, there's room for improvement: terrible communication with customers but rather easy solutions to implement.
Any experiences from other countries ?
--- rei_vilo
PostPosted: Fri Apr 16, 2010 6:05 pm
I've not needed to send mine in yet, but then it's a relatively new lens. The number is 929xxxx.
PhilipGoh.com
PostPosted: Fri Apr 16, 2010 6:47 pm
Bonsoir,
Any idea about Pentax lenses serial numbering, 7 digits starting with 9?
Best regards,
--- rei_vilo
