It is currently Mon Jan 23, 2017 12:22 am
PostPosted: Fri Mar 26, 2010 2:30 pm
Hi Guys
Im wanting help with an issue I have. The thing is can I fit a 2x tele-converter to it ? Do the two work together? I have a canon EOS 500d, and I bought the additional 70-300 lens, but I want to squeeze more length out of it, could the converter do it?
Thanks in advance for any help and advice
PostPosted: Fri Mar 26, 2010 5:33 pm
You may be able to fit a generic 2x teleconverter to it. Look at the back of the lens. How much space is there? Some teleconverters stick out, some don't, and depending on the lens they may not be mechanically compatible.
Do note even if you get it to fit, you wont be able to use AF any more as the aperture then becomes too small. Also the quality will take a hit. How much I couldn't say, but it may not be much more than if you just resized an image upwards. Finally do note you'll have a long focal length and small aperture, so even with OS, shake will likely become a big problem. A 1.4x will be less risky.
PostPosted: Fri Mar 26, 2010 7:18 pm
Popo wrote:
so even with OS
Which probably wont even work ;-)
EDIT: just 5 topics down or so, I found this topic too: http://www.cameralabs.com/forum/viewtopic.php?t=21254, please keep yourself from posting double threads if already asked by someone else. Please use the Search function in future cases to look for similar threads :-)
- Wout -
PostPosted: Fri Mar 26, 2010 7:27 pm
Not the same lens, but IS keeps trying to work when I stacked both a 2x and 1.4x on the 100-400L. Now that's a tricky one to hand hold even with IS...
PostPosted: Fri Mar 26, 2010 10:31 pm
Popo, there is only one Sigma 70-300 with OS!! It is the same lens. And what TC's are you using the 100-400, because it is necessary for the TC to have IS connectors.
EDIT: Oh wait :oops: you talk about the OS / IS part
- Wout -
Users browsing this forum: Bing [Bot] and 3 guests
