It is currently Thu Jun 20, 2013 11:41 am
 Post subject: 70-300mm lens help
PostPosted: Fri Mar 12, 2010 8:49 pm
newbie here. need a little info.
First off is there a way to remove the bayonet style lens hood without having to zoom the lens all the way out? When I twist it the lens starts to zoom out. So was just wondering what everyone does.
Question two. It only zooms out to 150mm. To get to 300mm I need to use the focus ring. but everything is blurry afterward. Is this how it is suppose to work. Not like my other lenses at all. they zoom all the way and the focus ring merely focuses.
"The quickest way to make money at photography is to sell your camera."
Olympus E-520
Zuiko 14-54mm II
Zuiko 70-300mm
Zuiko 50mm
B+W Filters
LowePro Classified 160
Lexar Professional Series Compact Flash
Olympus M+ 2 GB Flash Card
Optech Soft Case Pouches and Lens Sleeves
Optech Ez Comfort Neck Strap
California Sunbounce Sun-Sniper Camera Strap
PostPosted: Fri Mar 12, 2010 10:12 pm
Hood - pass. I just never used it when I had that lens...
The zoom, short answer, only look at the markings on the zoom ring, not the lens barrel, as from memory those only indicate the magnification at a given focal length.
PostPosted: Sat Mar 13, 2010 2:14 pm
You just need a short but forceful turn to get the lens hood off.
Olympus E-30, ZD 9-18mm 4.0-5.6, ZD 50mm Makro 2.0, ZD 14-54mm 2.8-3.5, ZD 70-300 4.0-5.6
Light travel equipment:
Olympus EP-2, µZD 14-42mm , Panasonic 20mm 1.7 pancake.
Cullmann Trento IT Daypack
 Post subject: Lens hood on 70-300
PostPosted: Wed Mar 24, 2010 3:49 am
To undo the lens cap I gently rotate the barrel out until I can get a couple of fingers in the gap. Then I hold the barrel with thumb and forefinger while unscrewing the cap. To attach the cap, I try to tighten the cap gently if there's no room to grip the barrel, or I grip the barrel and tighten.
Bottom line for me is grip the barrel while tightening/loosening wherever possible, or be as gentle as you can be when you can't. I just don't want this thing to go all wobbly on me until at least 30 years have passed. :)
E-620 : HLD-5 : 7-14mm : 8mm FE : 9-18mm : 12-60mm : 14-42mm : PL 25mm : 50mm Macro : 50-200mm SWD : 70-300mm : EC-14 : EC-20 : EX-25 : XZ-1
Flickr photostream
