It is currently Tue May 21, 2013 10:10 pm
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Mon Mar 22, 2010 11:42 pm
Hello dbnnet ! How are you ? Thanks for reply.
I saw some prices of UV filter and they are very cheap. Sounds strange for me, because lens Leica are $$$$, so put something in front "cheap one" will not reduce quality of photo and videos ?
Cheers,
Carlos
 Post subject: UV
PostPosted: Tue Mar 23, 2010 2:46 pm
cameks, Hi,
Because the diameter is small (only 46mm), they are not expensive, but I assure you that you should not need to worry too much about this.
Take a look at this:
http://www.kenrockwell.com/tech/filters.htm
"Multicoated is better than single coated, which is better than uncoated,
but the results are not usually visible at all....99.9% of the time there is no difference".
Regards
