It is currently Sat Jan 21, 2017 6:41 am
PostPosted: Wed Mar 17, 2010 8:20 pm
After watching the Canon flash Masterclass the other day, it was mentioned that you should still use lighting outdoors, even during decent sunlight, but is this really needed?
For Photographing outdoor landscapes, or just general objects like trees etc, what type of flash is ideal, is a standard flash gun suitable?
I guess it just depends on what the object(s) happen to be
Any opinons - leave them below :D
Canon EOS 500D
PostPosted: Wed Mar 17, 2010 9:09 pm
A photo is worth a thousand words. If this picture is not what you're after, yes, you need fill flash
Image :lol:
PostPosted: Wed Mar 17, 2010 9:17 pm
That is a studio setting, where the photographer (I'm guessing You) chose not to light the subject.
I would like to know whether fill flash is neccersary in Outdoor applications such as landscapes, and photographing people.
Canon EOS 500D
PostPosted: Wed Mar 17, 2010 9:32 pm
It's an example, the photo isn't even mine. I like to use a reflector outdoors, flash often can't sync fast enough or isn't powerful enough
PostPosted: Wed Mar 17, 2010 10:01 pm
How do you position the reflector, does it get held at the side of your camera?
Canon EOS 500D
PostPosted: Wed Mar 17, 2010 10:45 pm
It completely depends, just bounce some sunlight back into your models face! I tend to have it below at an angle to fill up the eyesockets and give "raccoon eyes" no chance.
PostPosted: Thu Mar 18, 2010 1:01 am
In answer to your question, no you do not use flash for landscapes. You can not possibly light up a whole scene with a flash no matter how powerful it is. If there is a lot of sky you want to capture then use a grad. filter to make sure the exposure is even and you do not blow out the sky while capturing detail in the foreground.
For people shots/portraits you can either use fill flash to make sure the subject is well lit or a reflector or a combination of both. Also meter from the subject with centre weighted metering or spot metering otherwise your camera will meter from the whole scene with matrix metering and you may get a dark subject because the camera is trying not to blow out highlights.
PostPosted: Mon Mar 22, 2010 12:55 pm
The following might help-
http://desmond-downs.blogspot.com/2010/ ... light.html
