It is currently Wed May 22, 2013 9:59 pm
 Post subject: Lightroom 2.6
PostPosted: Tue Mar 09, 2010 9:32 pm
Hi Guys
I have noticed a strange bug when I downloaded my photos directly from my compact flash.
I always do it with any developp settings, I just changed from raw to DNG, add my metadata... but since few days, Lightroom add some recovery, fill light, too much black, clarity and a lot of brightness and contrast...
and for sure it's totally wrong, my images are overexposed and full of noise
Somebody got already this bug ?
Thanks a lot, T
Thierry Dehove
http://www.thierrydehove.com/2009/01/04/professional-photography-studio-equipment/
PostPosted: Wed Mar 10, 2010 7:51 am
Have you reset the default controls settings in develop? Maybe somehow when you open a new image the settings from a previous image are being carried over.
I just replicated the issue after opening an image with quite heavy PP, then opening another and clicking on the Previous button. The settings from the first image were applied to the last one and the image was overexposed/noisy.
Canon EOS 50D/EF-S 18-55mm IS/EF-S 55250mm IS/EF 50mm F1.8 II /Lowepro AW Slingshot 200/ Digital Ixus 860 IS
PC>Q6700/MSI P45 Zilent/6GB 800mhz DDR2/2x 4870 1GB/Samsung Spinpoint F1 500GB/Maxtor 200GB+80GB
PostPosted: Wed Mar 10, 2010 1:31 pm
Hello Mike
let me share the panels
one the left when I upload the file and on the right what I should get
What do you think ?
what is amazing that when I upload from the 40D, I don't have this bug...
Thierry Dehove
PostPosted: Wed Mar 10, 2010 3:30 pm
That is very strange, and with those settings its no wonder the pictures are looking messed up!
Also strange that its only doing it with the 5D and not the 40D :?
All I can think to try is go to Develop/Set default settings... and click on Restore Adobe Defaults. Other than that I'm out of ideas. Good luck, or should that be bon chance!
PostPosted: Wed Mar 10, 2010 3:32 pm
it's what I am doing ;-)
very strange this bug suddenly
Thanks for your time
Thierry Dehove
PostPosted: Wed Mar 10, 2010 3:41 pm
No problem bud, if you find the cause and a solution it would be handy if you could post it here as I for one would be very interested!
PostPosted: Wed Mar 10, 2010 3:57 pm
Fir sure I will
doing some tests and I come to you later
Thanks, T
Thierry Dehove
PostPosted: Wed Mar 10, 2010 10:56 pm
look what I found Mike
http://lightroom-blog.com/2009/01/why-l ... cs-on.html
Thierry Dehove
PostPosted: Thu Mar 11, 2010 5:24 am
Interesting...So are you sorted now?
PostPosted: Thu Mar 11, 2010 3:53 pm
kind of.... but I will digg more to know why.. i will keep you posted ;-)
Thierry Dehove
PostPosted: Fri Mar 12, 2010 10:29 am
When importing from your card or folder there will be a drop down setting on the lightroom import window to add a develop setting, change this to none and all should be fine.
Also note that lightroom has a bad RAW convertor and can change the colour data slightly to the of the actual RAW.
Also to note when looking at the image on the back of the camera, this image is a processed image from the camera (jpeg) and when importing to the computer is a RAW (unprocessed) so it will look different. Using lightroom tools (exposure, white-balance) will fix this to your taste.
Mark Osborne
My life through an iPhone
PostPosted: Fri Mar 12, 2010 1:09 pm
Hi Orsan
it's exactly what I am doing each time none each time ;-)
and I converted RAW to PNG also.
Thanks, T
Thierry Dehove
