It is currently Sun May 19, 2013 6:21 am
 Post subject: Video on Sensors
PostPosted: Sun Feb 21, 2010 9:43 pm
I can't seem to find a direct description or diagram of this by Googling, so if somebody can direct me to material on it, or explain, I'd be most grateful.
When a digital still-image camera uses a video mode, the frame size is much smaller than the largest still image size available. Is the camera then using just a small area of the sensor, or does it use the whole sensor, but a very reduced number of pixels?
The question arises when comparing video from a camcorder, with a very small (comparatively) - sensor, and video from a still-image camera, at about the same frame size. The video from the camcorder seems to be of rather better quality, despite the smaller sensor.
Thanks, Dave.
PostPosted: Mon Feb 22, 2010 7:59 pm
One immediate giveaway if it were a crop would be a correspoding reduction in the field of view - like a digital zoom. So if you see no reduction when switching from stills to movie mode, then it's certainly using the full sensor width and height - well obviously some of the height is cropped for a 16:9 aspect ratio, but you know what I mean.
I've noticed some cameras slightly reduce the field of view in their movie modes, but not by a great deal, so it implies most of the sensor area is being used.
The question then is whether the movie mode ignores pixels it doesn't need to deliver a lower resolution video frame, or bins them for higher sensitivity. Hopefully it's the latter, but the manufacturers are always cagey about giving out the full details.
As for a camcorder being better quality, what are you describing? Noise, resolution, something else? And are you comparing it to a DSLR with video, or a compact camera movie mode?
PostPosted: Mon Feb 22, 2010 10:18 pm
I know for a fact that Nikon DSLRs drop every 8th line from the sensor to further decrease the output size, which results in massive stairstepping.
