It is currently Mon May 20, 2013 7:26 am
 Post subject: USB hub query
PostPosted: Wed Feb 03, 2010 9:42 pm
Not camera related ... but ..
if you had to connect 2 ipods to a pc via a non powered usb hub would itunes and indeed the pc recognise them both ... or are thre likely to be power issues ??
Haz camra .. can click
http://www.iainj.webs.com/ - under construction
PostPosted: Wed Feb 03, 2010 9:55 pm
It might be recognized but it will most likely not charge...or very slowly
PostPosted: Thu Feb 04, 2010 10:25 am
Most computer USB ports supply 500 milliamps of current. Some computers have more than one USB controller to support the number of USB connections, potentially giving you two 500 milliamp supplies from one computer.
There is quite an in depth article about USB power and how devices (including iPods) can make use of it here
http://www.girr.org/mac_stuff/usb_stuff.html
It suggests that iPods use almost all and sometimes more than the 500 milliamps supplied by the USB specification when charging.
Speedlight SB-700
http://keystrokesukimages.com
PostPosted: Thu Feb 04, 2010 8:49 pm
thankyou keystrokesuk
