It is currently Sat May 18, 2013 8:58 pm
 Post subject: Grafix Card
PostPosted: Sun Jan 24, 2010 4:44 pm
Can someone recommend one.
Need it to be duel output (also produce music so need duel screens) and be good enuff to show pics in half decent quality?
Any recommendations?
Nikon D90, MB-D80 Battery Grip
18-105mm f/3.5-5.6 VR Lens
Speedlight SB-600
Tamrac Expedition 5 Backpack
Sandisk Extreme 3 - 8gb
Vista Attaras Tripod
so far......
PostPosted: Sun Jan 24, 2010 5:24 pm
If you aren't fussed with 3D gaming performance this one should do the job of running dual displays. Image display quality is pretty much the same across the board for photos, the more expensive cards are really about 3d gaming performance. This ones about £50 and has dual DVI output.
http://www.ebuyer.com/product/190752
This one would be a better performer with faster memory in case you fancied a bit of light gaming! About £75.
http://www.ebuyer.com/product/167966
If you wait a few more weeks ATI should be releasing their budget 5xxx series cards which will give you DX11 support, but its not important other than being slightly more futureproof.
Canon EOS 50D/EF-S 18-55mm IS/EF-S 55250mm IS/EF 50mm F1.8 II /Lowepro AW Slingshot 200/ Digital Ixus 860 IS
PC>Q6700/MSI P45 Zilent/6GB 800mhz DDR2/2x 4870 1GB/Samsung Spinpoint F1 500GB/Maxtor 200GB+80GB
PostPosted: Mon Jan 25, 2010 2:23 pm
Ok cheers
Speedlight SB-600
so far......
PostPosted: Thu Jan 28, 2010 11:05 am
Not to mention that the new ATI cards will support triple-output :wink:
Canon 500D, 18-55mm IS, 55-200mm IS, Nissin Di622
