It is currently Sat May 25, 2013 11:53 pm
PostPosted: Wed Jan 13, 2010 9:00 am
I'd appreciate it if someone could give me the generic and/or Panasonic terminology for the plug pictured below.
The metal part of the plug measures exactly 8.28mm x 2.06mm at its widest points and it has 14 contacts.
Cheers.
PostPosted: Wed Jan 13, 2010 7:49 pm
What's on the other end of the cable? Is it the component HD cable?
PostPosted: Wed Jan 13, 2010 8:27 pm
It's got your standard RCA AV plugs on the other end; red, yellow and white.
PostPosted: Fri Jan 15, 2010 12:55 am
Then I assume it's a Panasonic TV-out cable...
PostPosted: Fri Jan 15, 2010 1:22 am
That's pretty much it.
On a slightly different note, do you think I could use the HDMI mini socket as an AV out to analogue equipment, like the RCA plugs?
What I would do is buy a Type C mini plug to Type A plug cable, chop off the Type A plug and hopefully been able to use the free wires in the same manner as a standard AV cable i.e. find wires that will do ground and signal.
Does HDMI HAVE to be connected to HDMI sockets at both ends or can you mix it up with bog standard AV?
PostPosted: Fri Jan 15, 2010 2:17 am
I don't think that's possible. I think HDMI only carries a digital signal.
If you want the analogue TV outputs from your Panasonic, you'll need to use your Panasonic AV port.
