It is currently Thu May 23, 2013 1:51 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Fri Jan 08, 2010 12:57 pm
Out of interest, was it bought form Amazon themselves or their marketplace sellers?
PostPosted: Fri Jan 08, 2010 12:59 pm
Direct from Amazon, as I did not want to risk buying a fake from the sellers.
PostPosted: Fri Jan 08, 2010 1:15 pm
Quote:
The problem is, I just tested it vs my Extreme IV 8GB card. It is slower in every test. Needless to say I will be contacting sandisk regarding this to check if 1. if it is real, 2. if it is a bad copy or something, as the performance is nothing like it should be. On my 7D the max burst for raw files is 28 over 5 seconds (I ran the test several times). With the Extreme IV I get 31.
Usually one test the burst rate by taking as many shots as you can before you can hear a small “break”. According to: http://www.digitalcamerareview.com/default.asp?newsID=4169&p=2 (and other sources) the rate should not change between a 300x and a 600x card, yet the time needed to restore the buffer should be lower.
PostPosted: Fri Jan 08, 2010 1:50 pm
I will test this some more as soon as I have a chance. I do find it funny that Sandisk support sent me to a page that shows lexar is king:)
PostPosted: Fri Jan 08, 2010 1:54 pm
http://www.robgalbraith.com/bins/conten ... 0044-10297
Which show lexar seem to be faster....
