It is currently Mon Jan 16, 2017 3:46 pm
PostPosted: Thu Jan 07, 2010 11:57 am
Hi everybody,
I'm new in this wonderfull world of foto.. I'm trying for a few months and experimenting with my new Canon 500D... I find it fascinating and total different as a Point and shoot camera.
Today I bought a new external flash - CUDE 250.. they have also a Syncronkabel... I've conected the SC to the Hotshoeadapter (SM-601).. the flash works wonderfull.. but in my camera menu I have not a menu for the external flash. It says that the flash is off or not kompatible. Any ideeas?
Thanks and best regards. :)
PostPosted: Thu Jan 07, 2010 3:42 pm
It may have something to do with the hot shoe adaptor.
Have you checked that flash is definately engaged, as if you were using the built in 'A' Frame flash?
Does the built in flash pop up?
PostPosted: Thu Jan 07, 2010 4:53 pm
You can't change settings on a flash through a sync cable, just trigger it. The idea is to put the flash in manual mode, set the power etc. The cable is just to tell the flash WHEN to fire.
PostPosted: Thu Jan 07, 2010 6:03 pm
correct, unless it has e-ttl functions.
PostPosted: Thu Jan 07, 2010 7:15 pm
The built in flash can not pop-up.. the hotshoe is there. I can set the power of the external flash manual from 1/8 - 1... but I thought that I'll have also a menu where to adjust it from camera :roll:
PostPosted: Thu Jan 07, 2010 7:18 pm
... how can I figure witch doesn#t has the TTL functions.. the flash or the Hotshoe? are there any settings that I can modify?
 Post subject: Burst Mode Question
PostPosted: Thu Jan 07, 2010 7:20 pm
I have a question actually.
If I am using Burst mode / continuous shooting, will the flash tolerate it, or will it have to recharge; incurring in a delay in between shots?
Canon EOS 500D
 Post subject: Re: Burst Mode Question
PostPosted: Thu Jan 07, 2010 8:27 pm
The pop-up flash will fire along the burst but will cover only the first shoots, the extern will have to charge (~1 sec. for 1/8 ).. but you can still make fotos
PostPosted: Thu Jan 07, 2010 8:37 pm
So, the shutter will still activate without the flash, then?
Canon EOS 500D
PostPosted: Thu Jan 07, 2010 8:51 pm
...the flash will be there.. but will be "empty" after the first foto.. the external needs 1-5 seconds to be full again.. the shutter bursts continuosly depending of your camera and in what format do you shoot RAW or jpeg.
PostPosted: Thu Jan 07, 2010 9:04 pm
Flash rate depends on the power used, and the recycle speed. More expensive flashes often recycle faster than cheaper ones. You might be able to get 2 FPS at low power though.
PostPosted: Sat Jan 16, 2010 10:32 am
That is correct. You'll get a severely underexposed photo as the flash did not fire but the camera had metered the scene expecting the flash to fire.
