It is currently Wed Jun 19, 2013 10:52 pm
 Post subject: which hoya filter ??
PostPosted: Thu Dec 10, 2009 12:50 am
Hi,
What is the difference between these two filter ?
Hoya HMC Haze UV(0) - Filter - UV - 67 mm
http://www.amazon.com/...UTF8&s=electro ... 990&sr=8-1
and
Hoya 67mm HMC Multicoated UV Filter
http://www.amazon.com/...UTF8&s=electro ... 059&sr=8-6
I am confused which one does what function and which one is better
 Post subject: Re: which hoya filter ??
PostPosted: Thu Dec 10, 2009 4:15 am
I just wanted to know if there is any difference between Haze UV (0) filter and the other one..
Thanks
sangfroid wrote:
Hi,
and
PostPosted: Thu Dec 10, 2009 10:16 am
Little impatient eh? ;) Bumping your thread so soon. Not so cold blooded after all perhaps? :D
Problem is your links don't work. You'd better fix that.
Ben
PostPosted: Thu Dec 10, 2009 12:04 pm
Long story short, multicoating is a special coating that prevents additional flare into your image if you shoot into the sun for instance.
I'd get the multicoated one ;)
PostPosted: Thu Dec 10, 2009 1:17 pm
haha... a bit sort of...
I think amazon changed link..it was working earlier...
By the way, after fitting these hoya filters, will i be still able to place lens cap on top of it ?
Ben
PostPosted: Thu Dec 10, 2009 3:31 pm
Usually not a problem. A filter has the same thread on its front as the thread it screws into. If your lens cap is of the type that grips the inside of the lens (in the filter thread) than it will do so too on the filter.
Ben
PostPosted: Thu Dec 10, 2009 4:06 pm
Ben
Provided they are not Slim(line) filters of course. Those usually cost more, so I think you would notice it.
I have a Hoya HMC filter and my lens cap fits perfectly.
