It is currently Tue Jan 24, 2017 5:35 pm
Post new topic Reply to topic  [ 83 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Mon Nov 30, 2009 7:59 pm
Thomas wrote:
Just installed the christmas-lights in the ivy at our door.
The *perfect* test-target for sagittal coma flare 8)
I hear there's this big bright thing called the sun, which is also a good flare-inducer? 8)
PostPosted: Mon Nov 30, 2009 8:09 pm
Well I don't think you would see the following effect shooting against the sun 8)
http://www.cameralabs.com/forum/viewtop ... 0497#90497
Why? You need a dark enough background to see the bird-like halo.
D810+assorted lenses
PostPosted: Mon Nov 30, 2009 8:45 pm
Update on prices in Germany:
With the availability of the lens more shops vie for a larger part of the cake. So the first reputable dealer offers the new zoom for below 2000EUR and even Amazon.de is already at 2213EUR (that is 1860 EUR without 19% VAT).
PostPosted: Mon Nov 30, 2009 8:49 pm
That explains ;)
PostPosted: Mon Nov 30, 2009 9:29 pm
Btw: With a max magnification of 1:8.3 you capture just 30x20 cm area at closest focus on a FX body. This is about the size of a DIN A4 sheet.
That is just about enough for a tight head-shot of an adult head. Surely not enough for close portraiture on babies :?
The (P)review is here.
PostPosted: Tue Dec 01, 2009 6:11 am
Is it a bad idea to buy a used 70-200mm at this point?
PostPosted: Tue Dec 01, 2009 12:50 pm
Elijah, this is not the topic for discussing this, I think we have also told you about this in your own thread(s). Please stay focussed on the 70-200VRII here, thanks in advance :-)
- Wout -
PostPosted: Tue Dec 01, 2009 8:04 pm
Lens arrived!
Currently shooting the first test-targets...
Hehe, I can totally dumbfound this lens :shock:
Using AF with only one AF-point exactly at the middle of the Siemens-star target at 2m distance, turned the focus ring to infinity, then half-pressed the shutter: Focus hunted from infinity to 1.4m and back to infinity. No focus confirmation came :twisted:
Don't think we're talking about a low-light situation here: Exposure measured 1/250 sec at f/2.8, ISO 200!
You can cure this strange effect by either switching to multiple AF-points, or pointing the camera a little off-centre, or using an off-centre focus-point.
Well, I blame the test-target. I must admit, that you could produce similar effects with other lenses too - sometimes.
PostPosted: Tue Dec 01, 2009 10:53 pm
Just did some prelim testing of VR.
At 200mm and 1/15 sec free standing (and naturally handheld) I get a lot of pretty good results. This would be equivalent to almost 4 stops
Not bad so far. Have to do more testing...
PostPosted: Wed Dec 02, 2009 6:44 am
how did you get your hands on the VR II
plust how slow of a shuter speed does the VR II work up to
PostPosted: Wed Dec 02, 2009 8:04 am
Just ordered one two months ago :D
1/15 sec at 200 focal length seems like the limit for my quality of handholding.
Expect slower shutter-speeds at shorter focal lengths, though. Perhaps 1/8 to 1/4 sec at 70mm focal length. Will test for that.
PostPosted: Wed Dec 02, 2009 9:51 am
I have had perfectly sharp pictures with my 70-300VR, at 70mm with 1/8s. Since this lens is a little heavier, I dont know if it will be the same, but hearing pro's talk that the VR has improved over the old one very much, I can only guess that it will indeed be the same.
- Wout -
PostPosted: Wed Dec 02, 2009 8:06 pm
After reviewing more shots at 1/15 sec and 200mm the new VRII seems to give a god hit-rate.
But:
I have to get into focus-testing big-time as some AF results are outright disappointing. And on my micro-focus test-chart sharpness was a little "jumpy".
Not good for my blood-pressure :(
PostPosted: Fri Dec 04, 2009 5:55 am
overall do you find it a good enough inprovement
to pay the 2400 dollars instead of a used 70-200 for 1500
is it worth the extra grand ?
PostPosted: Fri Dec 04, 2009 3:47 pm
Elijah, I cannot answer this Q as I did never have a version I in my possession. But there is almost consensus on the web that the "old" version is perfect on a DX body.
So if you never plan to migrate to FX (full-frame) that should answer your question.
