It is currently Fri May 24, 2013 8:59 am
PostPosted: Tue Nov 10, 2009 9:12 pm
Hi,
After a bit of advise, are the two brands compatible? ie will the b+w mount onto a hoya pro1 digital uv or are the threads incompatible?
I'm wanting a 6 stop nd for some long daylight exposures but hoya only go upto nd8 (3 stops).
Thanks in advance.
Nikon D90, 18-105mm vr,55-200 vr 50mm f1.8D, sb-600, sigma 10-20mm
Last edited by andrew morrow on Tue Nov 10, 2009 10:18 pm, edited 1 time in total.
PostPosted: Tue Nov 10, 2009 10:10 pm
I dont use the B&W mount, but the cokin system. Using Hoya pro1 on all my lenses the 2 systems are compatible (Cokin & Hoya). So I would guess the threads are pretty much standard across all systems
Alan
D4 & D700
http://www.alanwilliamsphotography.co.uk
BLOG: http://www.ayrshireweddingphotographer.org
