It is currently Thu May 23, 2013 9:33 pm
PostPosted: Wed Nov 04, 2009 1:22 am
I purchased an E-520 with the 14-42 lens kit. The lens image quality is really poor in long distance shots. In closeups with the new Fl-50 flash it works great !
I read that only three lenses are 100% compatible, but im interested in buying the 12-60 lens and in the begining it was not 100% compatible.
Does somebody know where i can see what lenses are really 100% compatible with the E-520 ?
Thanks for any help !
PostPosted: Wed Nov 04, 2009 2:43 am
there has never been a zuiko digital lens produced that is not compatible with the e-520. i think when you say compatible you are talking about the imager AF in Live View mode. every lens will perform the regular AF. don't count out the 14-42 lens just yet, it's a very underrated lens (unless you need it for low light work or super shallow depth of field).
www.iandavisphoto.com
aim s/n: idotddot
PostPosted: Wed Nov 04, 2009 5:22 am
Thanks a lot ! So you think the 12-60 will perform great on my E-520 ?
I saw a review and they said that the focus is slow in the lens-camera combination of a 12-60 and a E-520.
Does anybody own a E-520 and a Zuiko 12-60 lens ?
Thanks for any help.
PostPosted: Wed Nov 04, 2009 7:51 am
i own the e-520 and the 12-60. the ONLY times i've had focusing issues is in very low light. in good light (day light) the focus is fast.
aim s/n: idotddot
PostPosted: Wed Nov 04, 2009 5:12 pm
Thanks a lot, you think its worth to buy it ?
PostPosted: Wed Nov 04, 2009 5:28 pm
As has already been said, this only applies to live view.
Olympus E-30, ZD 9-18mm 4.0-5.6, ZD 50mm Makro 2.0, ZD 14-54mm 2.8-3.5, ZD 70-300 4.0-5.6
Light travel equipment:
Olympus EP-2, µZD 14-42mm , Panasonic 20mm 1.7 pancake.
Cullmann Trento IT Daypack
PostPosted: Wed Nov 04, 2009 5:35 pm
Thanks a lot !! Will try this combination. In january i upgrade to a E-3 or to canon 5D with 24-105 L !!
PostPosted: Thu Nov 05, 2009 12:57 am
I think it's still fast, but it's just that it works even faster in the E3.
Gordon reviewed the 12-60 http://www.cameralabs.com/reviews/Olympus_Zuiko_Digital_12-60mm_SWD/ here.
The only compatibility issue was that since the lens is relatively large, the e520 popup flash doesn't raise high enough, and you can get some barrel shadow using wide-angle + built-in flash. A hotshoe/external flash may be better if you're using flash photography
PostPosted: Thu Nov 05, 2009 4:56 am
Thanks Kimchi, y already have te Fl-50 external flash. I really recomend that flash. Its amazing !!
PostPosted: Fri Nov 06, 2009 3:43 am
I had an E-510 with 12-60 for about a year and the results were great. Not all that much better on the E-3.
E-3!
12-60 2.8-4.0
12-60 2.8-40 [Also going]
40-150 3.5-4.5
70-300 4.0-5.6
Fl-48
PostPosted: Wed Nov 11, 2009 2:38 pm
I have the E-520 and 12-60mm.... Autofocus is very fast in daylight as someone has already said. The low light is where is struggles... All in all it I noticed a dramatic difference in the lens from the standard lens.
