It is currently Thu Jan 19, 2017 3:08 pm
 Post subject: 2X teleconverters
PostPosted: Sat Dec 08, 2007 12:03 am
If you mount a 2X teleconverter does it automatically set your aperture to like f/8? Because if not couldn't I get one and mount it with my 50mm f/1.8 to make it a 100mm(150mm) f/1.8 with a minimum focusing distance of like 10in. would it make a good macro lens?
PostPosted: Sat Dec 08, 2007 12:22 am
Hi Nathan,
Check out this definition of f-number. If you double the effective focal length of a lens with a teleconverter then the best f-number also doubles (to 3.6 in your example). :cry:
PostPosted: Sat Dec 08, 2007 1:20 am
Oh, well still I think I would be able to get some good macro @ 100mm f/3.6 from like 10in. away.
PostPosted: Sat Dec 08, 2007 8:23 am
With every tele-converter the closest distance to the subject remains as with the original lens, only the manification is increased 2x (with a 2x converter that is).
So as your 50mm gets down to approx. 1:8 you'll be able to do 1:4 with a 2x converter - nothing more...
And beware:
1. You need a good converter
2. The optical resolution of every lens is reduced by 2
The latter may no pose a prob if the lens is very good and exceeds the sensor-resolution. But in some cases you may be equally well off to do digital-zooming in with pp.
D810+assorted lenses
PostPosted: Sat Dec 08, 2007 4:27 pm
Thanks guys I was just curious. I don't plan on picking one up any time soon or ever but I just wanted to about them. Thanks again.
PostPosted: Tue Dec 18, 2007 12:04 pm
I think teleconverters can be used well for astro-photography... Just check Gordons video regarding this topic: http://www.youtube.com/watch?v=lxTalp6f7kw
