It is currently Wed May 22, 2013 10:38 am
PostPosted: Sat Sep 05, 2009 8:01 pm
This white "spool" needs to be turned to the left in order to secure the film in place before use. However after having used two films with the camera since I started using it, the third time is proving a bit problematic becaue of this spool not turning.
Any ideas as to what might be preventign it from turning?
PostPosted: Thu Sep 17, 2009 5:06 am
Is the shutter already 'cocked'? Can you press the shutter release button as if you're taking a photo - if this clicks, then it may release the mechanism.
PostPosted: Fri Sep 18, 2009 5:53 pm
I'm not quite sure what cocked means even after briefly looking it up, though no I can not press the shutter release button and... release the shutter. Nothing seems to happen when I press the button.
PostPosted: Thu Oct 08, 2009 3:33 am
Bump?
PostPosted: Thu Oct 08, 2009 4:51 am
Think about a cocked gun.
Samsung GX-10, , SA 18-55mm
www.flickr.com/glxlr
PostPosted: Fri Oct 09, 2009 12:49 pm
But what does that mean?
ALso I've tried pressing the shutter release button and nothing happens.
PostPosted: Tue Nov 10, 2009 6:02 am
Cocked He means the little black lever on the top right corner of your photograph, he means is it already engaged?
My Photos:
PostPosted: Sun May 23, 2010 8:02 pm
Found the answer already?
I had the same with my XG-1, the problem was simple:
1: The camera was turned off (left mode-wheel)
2: The batteries are empty.
PostPosted: Mon May 24, 2010 3:23 pm
For the record, cocked basically means tension is applied to some mechanism, and it is ready to be released. Like the way you pull back a catapult. All you have to do to set it in motion, is release it.
