It is currently Tue May 21, 2013 7:21 am
PostPosted: Sat Sep 19, 2009 1:07 pm
hi i bouht a velbon sherpa 250r and i can figger out how to spred the legs out to get the head lower to the ground is there a clip you push or pull is you can help that would be great
PostPosted: Wed Sep 23, 2009 8:34 pm
Specs say: Minimum working height of 59cm, so I doubt you cán get any lower ;)
PostPosted: Wed Aug 25, 2010 1:59 pm
If it's anything like my 450, there might be a screw fitting on the bottom of the centre post, if there is, you should be able to unscrew the head and fit it to the bottom screw, your camera will be upside down, but you can easily rotate your photos in pp.
Hope this helps
Canon 50d, 50mm f/1.8, Sigma 135-400mm APO, Sigma 10-20mm, Lowepro backpack, Velbon tripod, Manfrotto 679 monopod, Hoya filters
www.flickr.com/amr276
Comment and help me learn!
