It is currently Wed May 22, 2013 10:48 pm
 Post subject: Old Canonballs
PostPosted: Fri Jul 31, 2009 6:50 am
Here's a shot I took a while ago in an old Spanish fortress here in San Juan. Any opinions are welcome.
Canon 40D w/vertical grip
Sigma 24-70mm EX DG f2.8
Canon EF 300mm f2.8 L USM
Canon 400mm f5.6 L USM
San Disk Ultra II 4gb
Manfrotto 681B
Canon 200 EG backpack.
PostPosted: Fri Jul 31, 2009 6:59 am
Nicely composed, but I think there's a bit of a bluish cast to it. Did you take it on the auto white balance setting? The A200 tends to make "cooler" images on the auto white balance setting and for best results you should manually select the white balance. This scene warrants a "Daylight" or "Cloudy" setting.
PhilipGoh.com
PostPosted: Fri Jul 31, 2009 7:09 am
I believe you are right sir.I don't remember changing the white balance for that shot.Thanks for you reply.
Manfrotto 681B
PostPosted: Fri Aug 14, 2009 9:10 pm
hmmm.. i think that you tried to compose it correctly. You followed the rule of thirds perfectly, but i don't feel that the composition is right. Maybe if you backed away from the cannonballs a little bit and put the pile of cannon balls off to the right or left of the frame. The picture now is a little plain, maybe mess with the tones a bit to juice it up a little. Sometimes changing little things can make all the difference. Remember this is all constructive criticism and i'm simply trying to help you for your pictures in the future. :wink:
Nikon D80/MB-D80/ ML-L3
AF-S 18-55 f/3.5-5.6, AF 50mm f/1.8D
SB-600
Vivtar 2800
My flickr
~Dan Nelson~
PostPosted: Sat Aug 15, 2009 3:53 am
Thanks a lot emp93!
Manfrotto 681B
PostPosted: Sat Aug 15, 2009 4:27 am
It is a common experience for many of us that makes the statement "knowing the rules is about knowing when to break them" true in photography. As Emp suggested, following the rules doesn't grantee a good picture.
Some fundamental points to think about, the most important being what you intend to show about your subject. In this case, what would you like to show about these cannon balls, and then gear your framing towards your established concept. For example, if I wanted to show the antiquity of war that these balls represent, I would encompass the cannon itself, or the setting, or post process it in such a way that shows the concept (sepia, high contrast, etc.)
a900 | D700
PostPosted: Sat Aug 15, 2009 5:25 am
Wow Dan's back :wink: this guys famous man and he's spot on. I think to me it looks like it's cut off, so a step or two back will do. (unless you were on the edge of a cliff)
Jake O'Connell, 40D Crew
my Blog
