It is currently Sat May 25, 2013 12:55 pm
PostPosted: Fri Jul 31, 2009 9:35 pm
Hello
Im trying to figure out how to set my white balance using a white or grey card, I go to FN then white balance menu then i go to manuel then I click on the right arrow then I take the picture, but it doesnt set my white balance correctly? not sure how it work
Thanks for any help!
PostPosted: Fri Jul 31, 2009 11:01 pm
oh yes :roll: I forgot to mention I have the K20D
PostPosted: Sat Aug 01, 2009 1:46 am
Hello ohfrankyboy
I didn't know the answer to your question however I did find a thread on the Pentaxforums.com website that may help with your problem.
Here is the direct link to the topic. I find that for Pentax specific questions, this site ususually has it.
http://www.pentaxforums.com/forums/general-photography-techniques-styles/43803-can-i-customize-whitebalance-camera-grey-card.html
Hope this helped
Model Mayhem
Facebook
PostPosted: Sat Aug 01, 2009 4:09 am
Thanks but still am confused :(
PostPosted: Wed Aug 05, 2009 8:09 pm
ok so how do you white balance on a grey or white card using your pentax k20d?
PostPosted: Thu Aug 06, 2009 3:44 am
Ok franky i think ive found your answer. It is instructions for the K10D but It should be the same menu system. If im understanding you correctly you want to use a white or gray card to adjust your wb manually depending on the environment you are in right? Here are the instructions on how to do so....
http://photographyrulez.blogspot.com/2008/06/manual-white-balance.html
Model Mayhem
Facebook
PostPosted: Thu Aug 06, 2009 5:05 am
thanks alot Slick3358 :)
PostPosted: Thu Aug 06, 2009 8:38 pm
no problem. Did that help you out?
Model Mayhem
Facebook
PostPosted: Mon Aug 10, 2009 3:48 am
thank you I think it did :)
