It is currently Thu May 23, 2013 2:40 pm
PostPosted: Tue Jun 02, 2009 5:27 pm
When I take a photo with a long exposure - the camera sorta makes some noise - I have had a Canon in the past and it did not do this - is this just normal with Olympus and a longer exposure - i'm talking like 2 plus seconds.
Thanks
Brandon
PostPosted: Tue Jun 02, 2009 5:52 pm
Is your image stabilization turned on? If so, the noise you are hearing is most likely that. When the IS is turned off you shouldn't hear anything other than the shutter.
www.iandavisphoto.com
aim s/n: idotddot
PostPosted: Tue Jun 02, 2009 7:17 pm
The whirring/grinding noise is the image stabilization. It is recommend you turn it off for exposures longer than 2 seconds.
E-3!
12-60 2.8-4.0
12-60 2.8-40 [Also going]
40-150 3.5-4.5
70-300 4.0-5.6
Fl-48
PostPosted: Tue Jun 02, 2009 7:23 pm
thanks alot guys - i know iS1 is on - I will check it out when I get home with it off.
Thanks alot and I love this lil camera so far. The size is great - I have a pancake lens on the way.
Regards,
Brandon
