It is currently Fri May 24, 2013 4:19 pm
 Post subject: Firmware Question
PostPosted: Fri May 29, 2009 5:49 pm
On the Olympus website there is a firmware support section. When I checked to see if my firmware was up to date I noticed that each update had either an Apple or Windows link. When I checked I chose Apple as I have an iMac and there were no updates. I then looked at the Windows link and found two updates, which applied to the same 70-300mm lens.
Why if I am shooting a photo with an E-520 not attached to any computer would Olympus update the lens for one OS and not the other?
Gear: Nikon D90, 18-105mm
PostPosted: Fri May 29, 2009 6:27 pm
find a friend with windows, install Olympus Master2 and update on their computer.
E-3!
12-60 2.8-4.0
12-60 2.8-40 [Also going]
40-150 3.5-4.5
70-300 4.0-5.6
Fl-48
PostPosted: Fri May 29, 2009 6:44 pm
I have a PC but I do not use it with my camera. I do not want to screw up my lens or make it PC only.
PostPosted: Fri May 29, 2009 8:11 pm
How exactly do you make a lens PC only?
Or the camera? I hate to be blunt, but don't be silly! If you connect the camera to a computer, the camera won't get "attached" the computer, its not a child :)
You're just using the computer to upload different firmware to the camera.
E-3!
12-60 2.8-4.0
40-150 3.5-4.5
70-300 4.0-5.6
Fl-48
PostPosted: Fri May 29, 2009 8:29 pm
Not knowing how software works, I would hate to download something that would over-ride the Mac OS and make it PC only.
In the past I have downloaded items after which I was told "you should not have done that" and it cost me much bucks to fix the problem. I still have the non working hard drive as a reminder.
Its okay to be blunt.
 Post subject: I Agree
I agree. I've used my E-410 on multiple computers, and i even updated it through a PC. Its not attached to one or the other, and still works perfectly fine on my Mac, so don't worry about it.
My Photos: http://flickr.com/photos/24648553@N04/
My Gear:
Olympus E-30
Olympus 14-54mm & 50mm Macro
FL-36
Lowepro Slingshot 200
 Post subject: Re: I Agree
PostPosted: Fri May 29, 2009 8:31 pm
Thanks, I would rather ask first than buy replacement parts later.
PostPosted: Fri May 29, 2009 11:55 pm
The only time this could ever be an issue is if you're using an iPod or something else with a hard drive that has to format in a specific type. Updating your camera with one or the other will not make the camera develop a liking to a particular OS.
E-3!
12-60 2.8-4.0
40-150 3.5-4.5
70-300 4.0-5.6
Fl-48
PostPosted: Sat May 30, 2009 12:17 am
Thanks for the info, my knowledge of computer stuff is just a notch above my expertise with a camera.
PostPosted: Sat May 30, 2009 12:35 am
No problem, feel free to ask anything. We were all beginners at one point.
E-3!
12-60 2.8-4.0
40-150 3.5-4.5
70-300 4.0-5.6
Fl-48
PostPosted: Sat May 30, 2009 12:34 pm
You can use Olympus Master with OS X, if memory serves me right
Olympus E-30, ZD 9-18mm 4.0-5.6, ZD 50mm Makro 2.0, ZD 14-54mm 2.8-3.5, ZD 70-300 4.0-5.6
Light travel equipment:
Olympus EP-2, µZD 14-42mm , Panasonic 20mm 1.7 pancake.
Cullmann Trento IT Daypack
PostPosted: Sat May 30, 2009 6:28 pm
Problem was that Olympus did not release the firmware updates for people using apple computers apparently.
E-3!
12-60 2.8-4.0
40-150 3.5-4.5
70-300 4.0-5.6
Fl-48
