It is currently Wed Jun 19, 2013 5:50 am
 Post subject: bag question.
PostPosted: Mon May 04, 2009 3:39 am
I think this is the best place to put this, i want to bike out of town to take some pictures, but my backpack i ordered isn't in yet, so i was going to attach the tri pod to the very back with string and have inside the main component my dslr with lens attached covered and surrounded by clothes, I'm referring to a normal backpack .
Check out: http://www.eagle1337.deviantart.com/
Camera: Canon Rebel T1i
Lens: Tokina 11-16mm f/2.8, Sigma 17-70mm OS DC HSM f/2.8-4, ef-s 18-55mm IS, ef-s 55-250mm IS. EF 50mm F/1.8
Tripod: Giottos MTL9351B with a MH 5001 head.
Bag: lowepro Slingshot 202 AW. Cards: Sandisk Ultra 2, Lexar MicroSDHC.
PostPosted: Mon May 04, 2009 4:46 am
Actually the bags and cases section would probably be better.
Edit: Appears as though the thread was moved, thanks mods!
PostPosted: Mon May 04, 2009 5:08 am
Hi eagle1337,
Against casual/normal friction type of impacts, that should be fine.
I assume you are talking about a bicycle and not a motorbike here. To increase the chances of "gear survival", I would recommend that you do not pack the camera with the lens attached. The lens-mount will take the brunt of the force and it is a vulnerable point on a camera.
A normal backpack with clothes in it, will protect your camera better than a regular photo-backpack. Only hard cases will truly protect your gear. The photo-backpacks are more designed for convenience through their use of compartments.
Good luck on your excursions!
Cheers :-)
PostPosted: Mon May 04, 2009 5:30 am
i see, yes it's just a pedal bike, i'll take the lens off then. cheers.
