It is currently Sun May 26, 2013 1:05 am
Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
 Post subject: AF Nikkor 50 mm 1:1.8D
PostPosted: Sun Nov 09, 2008 12:45 am
OK, I'm sure somebody else did a write-up on this particularly popular lens before, but I could not dig it up. Plus, whatever shooting that goes into this review has been done on a D40, on which this lens will work in manual focus only. Since many D40 owners are on a budget, this particular lens usually comes into consideration when the funds are right to expand on the lens department, at which point the lack of autofocus poses one big question mark. Nikon actually tried to remedy this with the new AF-S Nikkor 50 mm 1:1.4G but being one stop faster and four stops more expensive, I'm not so sure whether Nikon's intention was to serve the D40/40x/60 community, and in any case, the 'nifty fifty' sure is here to stay, at least for the moment. Anyway, here goes my experience with it.
1. Appearance & Build Quality:
Here, take a look:
Now I know this does not give much food for thought, but just look at the mount and you will get the point. Yes, despite being a full-frame (FX) lens, this is perhaps one of the smallest Nikkor lenses around. It is smaller (but heavier) than any incarnation of the 18-55 mm DX, the usual kit lens for the D40/40x/60 series. The build quality is well above average, with a firm and serious focus ring and a metal lens mount. The firmness of the focus ring is of special importance on the D40/40x/60, as it is your one and only means of focusing this lens. Considering the razor-thin depth of field to be expected at apertures of 1:2.8 and below, you want it to work perfectly. Mine does.
The lens extends forward a bit when focusing from one end to the other, but nothing too much. Unlike the kit lens, the front element does not rotate during focusing, making polarizing filters much less frustrating to use, although mounting them initially can be a little problematic (they tend to not screw all the way in, but it might be an issue with my filter rather than the lens). Better yet, the lens accepts 52 mm filters, so if you bought a bunch of them for the 18-55 and/or 55-200 mm DX, you can use them on this lens too. You can even use the same lens cap, but the hood (if you have it) will probably not fit.
2. Performance:
Focusing: As I have a D40, I can only focus by hand. But guess what, it is fun and it is fast. Tracking moving subjects (unless they are too far out to simply set the focus to infinity and keep it there) is almost impossible, but doable. Many people actually use this lens for portraits (for which it is perfectly suitable, with a 75 mm equivalent focal length and a large max. aperture) and for that, manual focus is OK. The minimum focus distance is 45 cm, so do not expect much of a macro capability.
How to focus by hand:
a. Chase the dot: All Nikon SLR cameras have a focus indicator dot at the lower left side of the viewfinder. When turning the focus ring, keep an eye on it. When it turns on, you got focus. Use the center focus point as it is the most sensitive, recompose as necessary. Do not forget that there is no focus lock on this: when you recompose, the dot will go away (and depending on how drastic you 'recompose', you may lose focus altogether. It takes some practice to get used to, but I did it in two days, and I am not particularly talented at this.
In low light, the AF assist lamp will not function: you can either measure subject distance and go from there, or keep a small flashlight (like the one doctors use to check eye response) and use it as a 'MF assist lamp'.
b. Rangefinder (D60 only): Nikon D60 has a built-in electronic rangefinder, which measures subject distance and displays it through the viewfinder, using the EV scale. Basically, try to keep the EV scale centered and you will be fine. This is how rangefinder cameras worked for the last century: Read the distance and/or distance feedback (+/-), set it on the lens (although they can make things easier by providing superimposed frames or direct distance read-outs, but you get the point. Even the cutting edge $10000 Leica M8.2 is manual-focus only.
Distortion: This is one of the reasons why you want a prime lens in the first place. There is NO distortion at any perceptible level. I am sure the guys at... some other sites, whatever, can (and will) give you an exact measure, but it is so low that even post-processing software can not correct it: they are so insensitive that even the smallest possible counter-input will correct it AND bend things the other way around. Just assume there is no distortion and go from there.
Vignetting: I can not test this without a special setup, but it is unrecognizable in the field. As this is a full-frame (FX) lens, the DX sensor will only use a central portion of the image circle, which usually counteracts whatever vignetting there might be in the first place.
Sharpness: Again, I can not give you any sort of scientific measure, having no test charts or anything, but I can assure you: You are in for a treat. Eliminating focal range flexibility (zoom) allows for complete and total optimization of rendering capabilities for the selected focal length, and the results speak for themselves. In fact, if you also have the sharpness turned all the way up from the Optimize Image menu, you might actually find that the finer details of images become jaggy and distorted on the LCD: the combined effect is so severe that the relatively low-resolution LCD screen can not properly render it!
BUT: You should expect particularly 'soft' results in the first few days of your endeavors with this lens. Here's why:
1. (If you are shooting with a D40/40x/60): It takes some time and practice to get used to focusing by hand. You will miss focus in some shots in this period and will probably not notice it immediately, thanks to the impressive sharpness (see above) of the lens. If you just shot something 'critical', then by all means zoom all the way in and confirm focus.
2. At apertures f/2.8 and larger, the depth of field becomes so narrow that even different parts of the same subject will not be in sharp focus. For instance, you may focus on a person and see that one shoulder is in sharp focus and the other (which was a fraction of an inch forward or backward) is not. In fact, I am willing to believe that the apertures below f/2.8 are there to achieve special soft-focus effects and creamy backgrounds, not to facilitate shooting in total darkness. For that, VR and flash are still the way to go.
3. Verdict:
If you can get used to the rather tight focal length (75 mm equivalent) and focusing by hand (D40/40x/60 folks) then by all means get one. For about $150, you get a lot of lens: it is compact, well-built, compatible with everything from manual focus film SLRs to the upcoming D3x and very, very sharp.
If you can pay about twice the cash, get the AF Nikkor 50 mm 1:1.4D instead. It is basically the same lens, but the build quality is even better and it has that one extra stop you never know when you will need.
If you can pay about 3.5-4 times the cash, get the AF-S Nikkor 50 mm 1:1.4G instead. It has a silent, fast AF motor which enabled proper autofocus on the D40/40x/60 (although you could sell off the D40, add the same amount of top of it, and get a hand-me-down D80 and the AF Nikkor 50 mm 1:18D) and the image quality should be equal, if not superior, to the non AF-S version.
If you want macro capabilities, this is not the lens you are looking for. You CAN shoot some macro with this, depending on the size of your subject, but the 45 cm min. focus distance is too far out to make it worthy. In fact, I found my 18-135 mm DX to be a better performer on that particular field. In this case, the 60 or 105 mm f/2.8 Micro is your pick.
4. Samples:
f/4.5, 1/400, ISO200
f/4, 1/200, ISO200
f/5.6, 1/80, ISO200
"Shoot RAW, ask questions later"
My Flickr Photostream. C&C Welcome!
Nikon D80 | AF-S Nikkor DX 18-135 mm f/3.5-5.6G ED | AF Nikkor 50 mm f/1.8D | AF Nikkor 70-210 mm f/4
PostPosted: Sun Nov 09, 2008 9:29 am
Hailstorm wrote:
[i]OK, I'm sure somebody else did a write-up on this particularly popular lens before, but I could not dig it up...
Me neither, though there is this thread over in the Lens Gallery for those who would like to see even more imagery. Thanks for an excellent contribution to the forum. 8)
PostPosted: Thu Nov 27, 2008 10:48 pm
I've added your review to this list.
It was a joy reading your experience with the lens. I liked how you avoided technical jargon, while providing real-life examples of this little wonder in action.
There's a thriving community of happy D40 + 50mm f/1.8D owners on Flickr - and also many people with the older 50mm Series E f/1.8.
Now, if you could get your hands on the new AF-S 50mm f/1.4, for a comparison... :)
Nikon D90 + MB-D80 + SB-600 + AF-S VR 18-200mm f/3.5-5.6 + AF-S 35mm f/1.8 + AF 85mm f/1.8 | My photos on Flickr.
PostPosted: Fri Dec 19, 2008 5:50 pm
Thanks for the great review!!! I often wondered about the 50mm 1.8 but since I belong to the D40 crowd, I always worried about the lack of autofocus.
After reading your review I guess I'll just get me one sometime next month and get used to focussing manually. Who knows, maybe I'll upgrade to a D90 someday and then I'll want to get it anyway...
Thanks for the encouragement,
happy holidays!
Bruno
Feel free to check out my website at
www.brunoaxhausen.com
PostPosted: Sat Jan 17, 2009 8:20 pm
That was a great read and incredibly sharp images.
http://www.flickr.com/photos/httpwwwfli ... adanbrood/
PostPosted: Mon Jan 19, 2009 9:34 pm
Hailstorm wrote:
In fact, I am willing to believe that the apertures below f/2.8 are there to achieve special soft-focus effects and creamy backgrounds, not to facilitate shooting in total darkness. For that, VR and flash are still the way to go...
Fair review that I've only just stumbled upon. I'll add two comments on the parts I've quoted above:
- Macro can be done well with the 50mm f/1.8 by adding a 52mm close up filter (+3 or 4) and this is a low cost way of getting into macro. It will be marked better than the 18-135mm f/3.5-5.6 paired up with the close up filters offered by Hoya.
- Larger apertures than f/2.8 don't have to be soft. It depends on the optical construction of the lens; the rare 28mm f/1.4 is sharpest practically wide open and softens as the aperture is stopped down because of diffraction.
Nikonian
PostPosted: Mon Jan 26, 2009 3:50 am
Hi! I am a new member and this is my first post. I enjoyed reading the review of this lens. It was the first additional lens I bought to go with my D40, as many others have done. The manual focussing is not a problem, in fact I find it makes me concentrate more on composition and all the other things one has to be aware of when taking a shot. I began like everyone else with the full auto mode on my D40 but now rarely use it or the scene modes. This lens has made me improve as a photographer and it is great for portraits although it may be a little too sharp as far as the ladies are concerned. It does show every skin blemish and a little healing brush is usually required in post-processing. I don't find it quite wide enough for general shooting, preferring my 28mm 2.8f for that. (the second prime I bought.) I may invest in an 85mm next. That should be all the primes I am likely to want or need.
PostPosted: Mon Jan 26, 2009 10:29 am
Hi Dave,
Thanks for the valuable feedback. And may I wish you a warm welcome to the CameraLabs forum. 8)
 Post subject: Excellent Review
PostPosted: Mon Jan 26, 2009 9:42 pm
Hailstorm,
I am really curious about how you processed your people's and "No War" shots in Capture NX. You were able to achieve spectacular contrast without losing a significant amount of color. That's AWESOME! What settings did you use?
Artem
PostPosted: Mon Jan 26, 2009 10:24 pm
Seems like some sort of clarity. Don't know what it's called in Capture, though.
Olympus shooter and a calm voice of reason.
 Post subject: Clarity
PostPosted: Tue Jan 27, 2009 2:33 am
But what does clarity actually do?
Artem
 Post subject: Re: Clarity
PostPosted: Tue Jan 27, 2009 2:37 am
I'm not quite sure but I think it might use a large radius, low % unsharp mask setting. It could boost color a bit too.
PostPosted: Tue Mar 10, 2009 1:00 am
I've just stumbled back on my older write-up. If anyone still wonders, the group shot was processed with the D2XMODE1 picture control and high pass filter with radius 100 and 40% opacity, blended as "overlay". Instant film-look, if you got your lighting right :)
PostPosted: Thu Mar 12, 2009 4:13 pm
First of all, thanks for a great review, happy you posted it.
I am myself planning on buying this lens, or a equivalent, but there is one thing that I can't get straight, so I was wondering if you maybe could help me out?
This lens focuses like many other ones to three meters focus distance, the rest is infinity, and as I understand that, it means that if you set the focus to infinity, everything further away than 3 meters from you will be in focus..? But that doesn't really go together with the fact that the small f number or big aperture creates a small depth of field and makes it impossible to get everything further away that 3 meters in sharp focus...
So my question is, can you take a shot, with f1.8, of a subject that is for example 10 meters away from you, and still achieve a small depth of field? I believe you can, but as I have described above it seems impossible....
I believe I have totally misunderstood this whole things, so please help me out....
Nikon D90 | Nikkor 18-105 AF-S f/3.5-5.6 VR | Nikkor AF 50mm f/1.8D | Nikon MB - D80 battery grip | Lowepro Flipside 200
Nokia 6220 5mp - Carl Zeiss optics
PostPosted: Wed Apr 01, 2009 9:45 am
I'm not an expert on the workings of focus and DOF, but from my experience, setting focus to a certain distance actually moves the center of the focus 'field' to that distance. The field has a depth determined by your aperture (hence the term DOF): the greater the depth, the more you will have in focus both fore and aft of your preset focus distance. Setting focus to 'infinity' means that the center of the focus plane can be laid on a subject further than the greatest finite distance on the focus scale, but the depth of (the) field will still be determined by the selected aperture. Thus, for instance, if you focus on a vehicle moving at 10 meters with an aperture of f/1.8, other subjects at, say, 300 meters will be out of focus. Still, the effect will be most pronounced on subjects closer to the camera (especially within the finite focus distance), giving the impression of a 'foreground bokeh', mostly due to perspective effects and the limitations in rendering small details.
