It is currently Thu Jan 19, 2017 6:04 pm
 Post subject: Sigma 70-300 DG Macro
PostPosted: Fri Aug 31, 2007 10:35 am
Hi,
Sorry for mass of topics on different lenses, but I keep finding new lenses and possibilities.
I've had a little go of the Sigma 70-300 in my local shop, I must say it felt quite good. However we did have a little trouble with the macro setting, it kept getting stuck in macro position. Is this a common thing? Or was the one I tried a defect?
Does anyone own one? Have any sample pictures?
Thanks alot,
Jack McIntyre
PostPosted: Sun Sep 02, 2007 12:40 pm
Hi Jack,
This from a user report for the Sigma 70-300mm f/4-5.6 DG Macro elsewhere on the Net:
The focussing mechanism uses a rotating (and extending) barrel. This causes problems when changing between normal and macro focusing ranges. In order to switch to macro, the lens must be within the 200mm-300mm range and to switch back to normal you must be focussed on a distant target. This can either be achieved using the auto focus or by flicking to manual. Either way it is a bit awkward.
Do you think that was the problem?
PostPosted: Sun Sep 02, 2007 2:03 pm
Bob Andersson wrote:
Hi Jack,
Hi,
Yeah it was, I had read about this on the internet and I knew what to do when it got stuck. But I didn't know if it was just with select models.
I've also been looking at the Sigma 18-200 F3.5-6.3 DC that Gordon has reviewed, turns out I might be able to get a part-exchange on my 18-55 Kit lens and get this lens alot cheaper than the £220 retail price. I also know the owner, so he might knock a little off if i'm lucky. :wink:
PostPosted: Tue Oct 16, 2007 5:16 am
Hi Jack
How did your deal go ?
Did you managed to get the 70-300mm lense ? OS ?
Any chance of a user review on this ?
Thanks
