It is currently Fri May 24, 2013 10:21 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 45 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Feb 25, 2009 8:51 pm
Oh LMAO well thats to bad but we'll watch it anyway :D
||Nikon D60|| ||18-55 Lens||Sigma 70-300mm||
[PnS] Olympus Fe-100 4MP
*Formally D80Freak
Flickr!
PostPosted: Wed Feb 25, 2009 9:00 pm
DD_nVidia wrote:
My 50kbps upload is saying "don't you dare!"
LOL!
buy some more bandwidth DD :P
Mark Osborne
My life through an iPhone
PostPosted: Wed Feb 25, 2009 9:55 pm
I want to.
I'd happily pay over £50 a month for 24Mb Down 8Mb Up...but alas, 8Mb Down 368Kb up is the best we can get.
MY FLICKR!
PostPosted: Wed Feb 25, 2009 10:39 pm
DD_nVidia wrote:
I want to.
im much the same...
Mark Osborne
PostPosted: Wed Feb 25, 2009 11:07 pm
DD_nVidia wrote:
I want to.
Well, think yourself lucky, because here i get about 400kps, on a good day in the summer, and on a bad day in the winter we get about 100kps, thats just down, so think yourself lucky :lol:
Also, have you posted a thread about the video your making because i am looking forward to it :wink:
Ta
Ed
Saving for: -
PostPosted: Thu Feb 26, 2009 3:20 am
DD_nVidia wrote:
I want to.
man i thought mine was slow :(
anywho i am hoping your talking kb not mb because 24mb down and 8mb up is fast!
but mine is free through work so I cant complain :P
Nikon D80
18-55mm Vr
55-200mm Vr
http://agleisberg.com
PostPosted: Thu Feb 26, 2009 8:07 pm
The aforementioned SAS Drives
I just got them today
2 x Seagate Cheetah 15,500 RPM SAS Drives.
just going to take pictures of all the bits (geek tradition duh!) then im building this bad boy!
MY FLICKR!
PostPosted: Fri Feb 27, 2009 1:18 am
it went to 3.97 from 2.66 on stock cooling in a very hot room with 10 seconds on super pi - it is miliseconds away from 9 seconds!!
I had 4.008Mhz but it BSOD >_<
MY FLICKR!
PostPosted: Fri Feb 27, 2009 6:17 am
Well, what are the temps after 10 minutes of prime95?
PostPosted: Fri Feb 27, 2009 9:19 am
ill tell you later 8)
ahahaa!
But yeah i will run it.
want it running on all 4 cores i assume?
MY FLICKR!
PostPosted: Fri Feb 27, 2009 9:41 am
Hi Daniel,
While the "Off-topic" section was absolutely the right place for this thread initially it has now settled down into a computer hardware thread so I've moved it here. I've left a "shadow" behind so everyone can find it.
If you think I've got it wrong then by all means let me know why and I'll reconsider. 8)
PostPosted: Fri Feb 27, 2009 10:55 am
ahahaa!
Yes you want it running on all four cores, and to be certain its stable you want it to be running for quite a while.
I usually run Large FFT's and let it run for a several hours. If your OC can survive this then your going to be 100% certain that your as stable as running it at stock speeds.
I usually run prime for a day just to make sure.
Nikon D80
18-55mm Vr
55-200mm Vr
PostPosted: Fri Feb 27, 2009 11:19 am
Remember to use Prime95 25.5 or later. this one utilizes all 4 cores. 2 hours stable at full utilization is enough for me.
PostPosted: Fri Feb 27, 2009 12:25 pm
I miss the smell of hot thermal compound in the morning :D
I believe the fave stress test at the moment is one of the linpack derived ones, of which there are several versions floating around. The claim is that linpack ones can find failures quicker than prime95, and will get things hotter faster too.
I believe Linpack will more likely uncover ram or northbridge related stability issues as it uses a very large data set and will stress the memory interface heavily. Prime95 tends to work on small data sets which will substantially of not completely fit in the CPU's cache and therefore stress the CPU itself more, but less the interfaces out. Personally I tend to do runs of prime95 AND linpack just to be absolutely safe.
Also I'd run memtest86+, at least 3 passes. That concentrates on the ram specifically which you should do as well particularly if overclocking that. I've been bitten before by a minor instability eventually tracked down to an obscure memory timing where the bios defaults were unstuitable. It would pass single runs, and might only show up one error an hour, but that is still one too many.
PostPosted: Sat Feb 28, 2009 6:08 pm
Hi Daniel,
As requested in your PM I've now locked this thread so that the conversation can continue in your new thread Core i7 Photo Editing PC. 8)
